IMG_20210212_163450|690x385 I've tried to set up with different methods over and over again, but it's always the same error
No logs == No problem.
You may try using a separate $esp (create manually before installation) and select it as efi/$esp partition in installer.
You may also try garuda-chroot to enter in the installation and manually setup $esp to /boot/efi and install grub there.
If my answer was a proven solution, post what you did and succeeded.
Or just say you didn't like the answer. It's not polite to not give feedback and only mark a post as solution.
