Don't think that's the problem tbh, I've used Garuda KDE for a few months before and it's worked perfectly fine.
Good game!
@Calimari Can you post the steps you took to fix this for any further users having such issues?
Only if no iGPU is in use.
The installation process need more RAM, IIRC, for KDE, maybe we must write 8 GB.
I wish no one on the forum would answer until the person seeking help has posted their
inxi -Faz
Lucky boy
, but I think it works not smooth until you change some graphic settings.
Indeed, nohang did automatically terminate programs sometimes. A few tweaks had that fixed, though. Garuda works surprisingly well on my laptop, better than any other distro I've used. Maybe it's the prebuilt optimization?
Not that I saw, you suggested chrooting and installing grub.
Except that calamares is configurable so the general flow doesnāt have much impact on a specific distribution. In garudaās case, looking at the config, it looks like there is an additional module called postcfg which happens after bootloader installation.
While you probably could get a system like that working, I donāt think it is the first option to recommend. ![]()
I was geniuenly asking, It was fooling of me not suggesting a re install. I apologize .
