Infinix x2 plus no wifi and no sound
Wifi not showing/working and sound not coming from speakers
Kernel: 6.2.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
misobasedir=garuda root=miso:LABEL=GARUDA_DR460NIZED_RAPTOR quiet
systemd.show_status=1 ibt=off driver=free nouveau.modeset=1
Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Infinix product: Infinix INBOOK X2 PLUS v: N/A
Mobo: Infinix model: EM_TG325_200B_V1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: TGL_TG325_200B_IN_V5.1.10 date: 08/22/2022
ID-1: BAT0 charge: 36.0 Wh (72.0%) condition: 50.0/50.0 Wh (100.0%)
volts: 11.6 min: N/A model: Intel SR 1 SR Real Battery type: Unknown
Info: model: 11th Gen Intel Core i3-1115G4 bits: 64 type: MT MCP
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 2
microcode: 0x28
L1: 160 KiB desc: d-2x48 KiB; i-2x32 KiB L2: 2.5 MiB desc: 2x1.2 MiB
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1260 high: 1300 min/max: 400/3000 scaling:
driver: intel_pstate governor: powersave cores: 1: 1300 2: 1264 3: 1300
4: 1177 bogomips: 23961
Device-1: Intel Tiger Lake-LP GT2 [UHD Graphics G4] vendor: nCipher Security
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9a78 class-ID: 0300
Device-2: Microdia USB 2.0 Camera type: USB driver: uvcvideo bus-ID: 3-5:3
chip-ID: 0c45:6368 class-ID: 0e02 serial: <filter>
Monitor-1: eDP-1 model: BOE Display ▒ NV156FHM-N61 built: 2022
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
API: OpenGL v: 4.6 Mesa 22.3.6 renderer: Mesa Intel UHD Graphics (TGL GT2)
direct-render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Emdoor Digital
chip-ID: 8086:a0c8 class-ID: 0401
Sound API: ALSA v: k6.2.7-zen1-1-zen running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: N/A modules: iwlwifi bus-ID: 00:14.3
IF-ID-1: enp0s20f0u2 state: unknown speed: -1 duplex: half mac: <filter>
driver: btusb v: 0.8 bus-ID: 3-10:4 chip-ID: 8087:0aaa class-ID: e001
Device-2: ASUSTek Zenfone GO (ZB500KL) (RNDIS mode) type: USB
driver: rndis_host v: kernel bus-ID: 3-2:6 chip-ID: 0b05:7774 class-ID: 0a00
Local Storage: total: 491.26 GiB used: 0 KiB (0.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Foresee model: VP1000F512G
lanes: 4 type: SSD serial: <filter> rev: V1.25 temp: 31.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: Cruzer Blade
size: 14.32 GiB block-size: physical: 512 B logical: 512 B type: N/A
ID-1: swap-1 type: zram size: 7.51 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 57.0 C mobo: N/A
Processes: 185 Uptime: 23m wakeups: 20806 Memory: 7.51 GiB
used: 3.62 GiB (48.2%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1181
libs: 308 tools: octopi,paru Shell: fish v: 3.6.0 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.25
Please, post full garuda-inxi.
Did you reboot after update?
it's full inxi
I just booted live to check wifi or sound working, as they weren't working in other distros too.
but working in windows
Yes, but not full garuda-inxi.
This part is missing
Garuda (2.6.15-1):
System install date:     2021-08-05
Last full system update: 2023-03-22 ↻
wifi issue resolved, just installed Intel wifi drivers from intel official page,
but sound issue still there
thanks btw :slight_smile: .
actually booted in live environment, still not installed
Ask me again when it is installed.
And the garuda-inxi also works from the live ISO.
Here's full inxi
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 exit lang=en_US keytable=us
tz=UTC misobasedir=garuda root=miso:LABEL=GARUDA_DR460NIZED_RAPTOR quiet
i915.modeset=1 radeon.modeset=1 snd_hda_intel.dmic_detect=0
ID-1: BAT0 charge: 28.5 Wh (57.0%) condition: 50.0/50.0 Wh (100.0%)
microcode: 0x28
Speed (MHz): avg: 1141 high: 1339 min/max: 400/3000 scaling:
driver: intel_pstate governor: powersave cores: 1: 1322 2: 1241 3: 1339
4: 665 bogomips: 23961
direct-render: Yes
bus-ID: 00:1f.3 chip-ID: 8086:a0c8 class-ID: 0401
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
lanes: 4 type: SSD serial: <filter> rev: V1.25 temp: 30.9 C scheme: GPT
System Temperatures: cpu: 52.0 C mobo: N/A
Processes: 188 Uptime: 31m wakeups: 43690 Memory: 7.51 GiB
used: 3.14 GiB (41.8%) Init: systemd v: 253 default: graphical
Garuda (2.6.15-1):
System install date:     2023-03-22
sir, I just want to check before moving to it.
the sound problem probably comes down to an incorrect output configuration. I assume it uses some headphone port, but not your speakers.
Try fiddling around with the KDE audio settings. If you can't get it to work, feel free to ask.
just noticed, sound is coming but its too low to be audible.
even after increasing to 150%, not audible, but audio starts breaking
