After installing garuda linux, I have seen that the inbuilt keyboard is not working to wake up the laptop from sleep.
No key is working to wake up the pc. I am forced to do the restart everytime it goes to sleep.
I have tried to see the bios settings, but no help in there. I even enabled the virtual keyborad. But I don’t think that helps.
I am newbie, and sorry if I don’t know something. Please help.
Kernel: 6.17.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=3fb0114a-26da-4ad2-bdbb-b811e6ac4725 rw rootflags=subvol=@
quiet loglevel=3
Desktop: KDE Plasma v: 6.5.3 tk: Qt v: N/A info: frameworks v: 6.20.0
Type: Laptop System: HP product: Victus by HP Gaming Laptop 15-fa2xxx v: N/A
Mobo: HP model: 8DCD v: 50.09 serial: <superuser required>
part-nu: C91SXPA#ACJ uuid: <superuser required> Firmware: UEFI vendor: AMI
v: F.04 date: 05/13/2025
ID-1: BAT0 charge: 46.3 Wh (68.7%) condition: 67.5/70.1 Wh (96.3%)
power: 23.7 W volts: 15.62 min: 15.4 model: HP Primary type: Li-ion
serial: <filter> charging: status: discharging cycles: 61
Info: model: 13th Gen Intel Core i5-13420H bits: 64 type: MST AMCP
process: Intel 7 (10nm) family: 6 model-id: 0xBA (186) stepping: 2
microcode: 0x6133
Topology: cpus: 1x dies: 1 clusters: 5 cores: 8 threads: 12 mt: 4 tpc: 2
st: 4 smt: enabled cache: L1: 704 KiB desc: d-4x32 KiB, 4x48 KiB; i-4x32
KiB, 4x64 KiB L2: 7 MiB desc: 4x1.2 MiB, 1x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 400 min/max: 400/4600:3400 scaling: driver: intel_pstate
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 9: 400 10: 400 11: 400 12: 400 bogomips: 62668
Device-1: Intel Raptor Lake-P [UHD Graphics] vendor: Hewlett-Packard
built: 2020-21 ports: active: eDP-1 empty: DP-1 bus-ID: 00:02.0
chip-ID: 8086:a7a8 class-ID: 0300
Device-2: NVIDIA AD107M [GeForce RTX 4050 Max-Q / Mobile]
vendor: Hewlett-Packard driver: nvidia v: 580.105.08
alternate: nouveau,nvidia_drm non-free: 550-580.xx+
status: current (as of 2025-11) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s ports: active: none empty: HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:28a1 class-ID: 0300
Device-3: Luxvisions Innotech HP Wide Vision HD Camera driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:2
chip-ID: 30c9:0069 class-ID: fe01 serial: <filter>
compositor: kwin_wayland driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: BOE Display 0x0cfd built: 2023 res:
mode: 1920x1080 hz: 144 scale: 100% (1) dpi: 142 gamma: 1.2
modes: 1920x1080
inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.2.7-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-P)
device-ID: 8086:a7a8 memory: 14.89 GiB unified: yes display-ID: :0.0
API: Vulkan v: 1.4.328 layers: 7 device: 0 type: integrated-gpu
name: Intel Graphics (RPL-P) driver: mesa intel v: 25.2.7-arch1.1
device-ID: 8086:a7a8 surfaces: N/A device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 4050 Laptop GPU driver: nvidia v: 580.105.08
device-ID: 10de:28a1 surfaces: N/A device: 2 type: cpu name: llvmpipe
(LLVM 21.1.5 256 bits) driver: mesa llvmpipe v: 25.2.7-arch1.1 (LLVM
21.1.5) device-ID: 10005:0000 surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info
Device-1: Intel Raptor Lake-P/U/H cAVS vendor: Hewlett-Packard
driver: sof-audio-pci-intel-tgl alternate: snd_soc_avs,
snd_sof_pci_intel_tgl, snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:51ca
class-ID: 0401
Device-2: NVIDIA AD107 High Definition Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:22be
API: ALSA v: k6.17.9-zen1-1-zen status: kernel-api tools: N/A
Device-1: Realtek RTL8852BE-VT PCIe 802.11ax Wireless Network
vendor: Hewlett-Packard driver: rtw89_8852bte v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 03:00.0 chip-ID: 10ec:b520
lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-7:3 chip-ID: 0bda:b86a
Local Storage: total: 476.94 GiB used: 23 GiB (4.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: BC901 HFS512GEJ9X108N size: 476.94 GiB block-size: physical: 512 B
fw-rev: HPS2 temp: 32.9 C scheme: GPT
ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 22.94 GiB (22.9%)
used: 63.7 MiB (24.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 100 GiB size: 100 GiB (100.00%)
used: 22.94 GiB (22.9%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-4: /var/log raw-size: 100 GiB size: 100 GiB (100.00%)
ID-5: /var/tmp raw-size: 100 GiB size: 100 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.24 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: N/A mobo: N/A
Fan Speeds (rpm): cpu: 2195 fan-2: 2036
Memory: total: 16 GiB note: est. available: 15.24 GiB used: 3.33 GiB (21.8%)
Processes: 314 Power: uptime: 7m states: freeze,mem,disk suspend: s2idle
image: 6.05 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 258 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1342 libs: 350 tools: octopi,paru Compilers:
gcc: 15.2.1 Shell: Bash v: 5.3.3 default: fish v: 4.2.1 running-in: konsole
inxi: 3.3.40
Garuda (2.11.1-1):
System install date: 2025-11-29
Garuda release: 250801
Last full system update: 2025-12-02
Relevant software: snapper NetworkManager dracut nvidia-utils nvidia-open-dkms garuda-hardware-profile-nvidia garuda-hardware-profile-standard garuda-hardware-profile-standard-x11
25/26 checks run in 1.26 seconds ⌛
Powered by garuda-health 🦅
--- LOW ---
- PackageKit is currently installed. PackageKit (Discover, GNOME Software) is not a supported method to manage packages on Garuda Linux. https://wiki.garudalinux.org/avoid-packagekit (fix available)
