Images not loading in Vivaldi or any of my other browsers
root=UUID=013a0e6f-1e15-4ec6-8862-4c62cb69ca18 rw rootflags=subvol=@
quiet rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 info: latte-dock
wm: kwin_x11 vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING (WI-FI) v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3202
date: 06/15/2023
Info: model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA50000D
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1876 high: 4244 min/max: 400/4464 scaling:
driver: amd-pstate-epp governor: performance cores: 1: 3725 2: 4011 3: 400
4: 3716 5: 400 6: 400 7: 400 8: 4018 9: 4244 10: 400 11: 400 12: 400
bogomips: 93422
built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0
chip-ID: 1002:67df class-ID: 0300 temp: 58.0 C
Device-2: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2 chip-ID: 046d:0825
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: SCEI MONITOR serial: <filter>
built: 2011 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
size: 522x294mm (20.55x11.57") diag: 600mm (23.6") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
inactive: gbm,wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 480 Graphics
(polaris10 LLVM 16.0.6 DRM 3.54 6.5.9-zen2-1-zen) device-ID: 1002:67df
memory: 7.81 GiB unified: no
API: Vulkan v: 1.3.269 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 480 Graphics (RADV POLARIS10) driver: mesa radv
v: 23.2.1-arch1.2 device-ID: 1002:67df surfaces: xcb,xlib device: 1
type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
v: 23.2.1-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000 surfaces: xcb,xlib
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.1 chip-ID: 1002:1637
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.6 chip-ID: 1022:15e3
Device-4: Logitech [G533 Wireless Headset Dongle]
lanes: 1 mode: 1.1 bus-ID: 1-7.1:7 chip-ID: 046d:0a66 class-ID: 0300
Device-5: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 06:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:9 chip-ID: 8087:0029
Local Storage: total: 1.36 TiB used: 391.42 GiB (28.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
tech: SSD serial: <filter> fw-rev: 043 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT500MX500SSD1
used: 391.42 GiB (84.1%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 1.2 MiB (0.4%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: zram size: 15.41 GiB used: 9.5 MiB (0.1%) priority: 100
System Temperatures: cpu: 43.1 C mobo: N/A gpu: amdgpu temp: 58.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 729
Processes: 338 Uptime: 17m wakeups: 0 Memory: total: 16 GiB note: est.
available: 15.41 GiB used: 4.11 GiB (26.7%) Init: systemd v: 254
Packages: 2127 pm: pacman pkgs: 2124 libs: 578 tools: octopi,pamac,paru,yay
pm: snap pkgs: 3 Shell: fish v: 3.6.1 default: Bash v: 5.2.15
Garuda (2.6.17-1):
System install date:     2023-11-01
Last full system update: 2023-11-01
I have searched the web thinking it might not be a Gurada problem, which it may not be, but I am at my wits end trying to figure this out. Any help would be greatly appreciated!
This may or may not be related to your issue, but:
It looks like you just installed this system today, but you are using mkinitcpio. Did you manually switch from dracut to mkinitcpio, or are you using an old ISO?
Regarding the issue with images loading in the browser, can you be more specific? Do you notice the issue on certain sites, for example? Perhaps you can upload a screenshot to the thread so we can take a look.
Probably the reason it looks like I installed it today is because I’ve been messing around with the snapshots to try to fix the problem. I have 2 ssds one with windows, and one with Garuda. The same site works on the windows side of it which I only use when I have to. I appreciate the prompt reply!
I don’t think there is anything wrong with your browser; I just went to this URL (Skinned Williams Defender Conversion Replacement CPO Control Deck for — DIY Retro Arcade) and discovered there is no image on the page.
I just tried it on vivaldi on the windows drive and it worked. It is strange. I can’t say it’s vivaldi because I’v tried it on Chrome and others and the same thing. It’s a puzzle I guess, but it is getting kind of annoying but I appreciate any help I can get.
I’m not sure, but it seems like it might be an issue with that webpage (as opposed to an issue with the browser). The browser I tested in does not have an issue displaying images.
Thanks! I just thought maybe the webpage can detect if I’m on windows or not, which would be pretty lame.
Typically your browser reports a lot more information than that, actually. :grimacing:
Take a look for yourself:
