Hello. I started to notice something like this in garuda. I install Yandex browser, then Google Chrome, then Microsoft Edge, all these browsers on Chrome. And when I launch them, I install one or another and start surfing, then the image on the monitor disappears, the monitor seems to restart, even the button on it turns off and on again. I print with firedragon now and everything is fine.
Kernel: 6.12.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=cae271f6-f01b-47f6-ba22-b599e38b9141 rw rootflags=subvol=@
Type: Desktop Mobo: Micro-Star model: B450M MORTAR MAX (MS-7B89) v: 1.0
Megatrends LLC. v: 2.K0 date: 10/20/2023
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 2
desc: 6x512 KiB L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 1722 min/max: 550/4208 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1722 2: 1722 3: 1722
4: 1722 5: 1722 6: 1722 7: 1722 8: 1722 9: 1722 10: 1722 11: 1722 12: 1722
bogomips: 86397
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21 [Radeon RX 6800/6800 XT
/ 6900 XT] vendor: ASRock driver: amdgpu v: kernel arch: RDNA-2
speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1, DP-2, DP-3,
Writeback-1 bus-ID: 28:00.0 chip-ID: 1002:73bf class-ID: 0300
gpu: amdgpu display-ID: 0
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.1-arch1.3
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6800 (radeonsi navi21
LLVM 18.1.8 DRM 3.59 6.12.4-zen1-1-zen) device-ID: 1002:73bf
API: Vulkan v: 1.4.303 layers: 14 device: 0 type: discrete-gpu name: AMD
Radeon RX 6800 (RADV NAVI21) driver: N/A device-ID: 1002:73bf
bus-ID: 28:00.1 chip-ID: 1002:ab28 class-ID: 0403
speed: 16 GT/s lanes: 16 bus-ID: 2a:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: ASUSTek TUF GAMING H5/H7
lanes: 1 mode: 1.1 bus-ID: 1-10:5 chip-ID: 0b05:189c class-ID: 0300
API: ALSA v: k6.12.4-zen1-1-zen status: kernel-api with: aoss
IF: enp34s0 state: up speed: 100 Mbps duplex: full mac: <filter>
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3
Local Storage: total: 1.47 TiB used: 822.88 GiB (54.5%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Western Digital
model: WD BLACK SN750 SE 500GB size: 465.76 GiB block-size: physical: 512 B
fw-rev: 711250WD temp: 40.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: AMD Radeon model: R5MP120G8
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: T1103F0L temp: 40.9 C
model: WD10EZEX-75WN4A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
ID-1: / raw-size: 111.5 GiB size: 111.5 GiB (100.00%)
used: 19.04 GiB (17.1%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
ID-3: /home raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
used: 376.49 GiB (80.8%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-4: /var/log raw-size: 111.5 GiB size: 111.5 GiB (100.00%)
ID-5: /var/tmp raw-size: 111.5 GiB size: 111.5 GiB (100.00%)
System Temperatures: cpu: 39.1 C mobo: N/A gpu: amdgpu temp: 58.0 C
mem: 52.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 906
Memory: total: 16 GiB available: 15.54 GiB used: 5.36 GiB (34.5%)
Processes: 393 Power: uptime: 3h 38m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.2 GiB services: org_kde_powerdevil,
Packages: 1816 pm: pacman pkgs: 1773 libs: 529 tools: octopi,pamac,paru
pm: flatpak pkgs: 43 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.36
System install date: 2024-12-17
Last full system update: 2024-12-18 ↻
The question seems to be resolved. Probem is not in browsers and not in Garuda Linux. The problem is that my RAM is not chasing. Memtest pointed to many errors during acceleration and 0 without overclocking.
