This is a somewhat recent issue (started maybe a month ago?). If my monitor falls asleep or if I turn it off and try to wake/turn it on later, it gives me "no signal". Note this is waking the monitor from sleep, not the system (the system is set to never sleep). When I jiggle the mouse the monitor turns on, displays a gray screen, then gives me "no signal". So it's definitely getting something from the system. There's another issue that may be related: when I start my computer and get to the login screen, the monitor is on but it's just a black screen. I only get video after I input my password and hit enter.
garuda-inxi output:
root=UUID=6276c6a9-723f-47e6-a43b-06f7b629b5b5 rw rootflags=subvol=@
resume=UUID=a0a9f712-b7b9-4caf-974c-8def2b54643e loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.26.1 tk: Qt v: 5.15.6 info: latte-dock
Type: Laptop System: Alienware product: Alienware m15 R3 v: 1.20.0
Mobo: Alienware model: Alienware m15 R3 v: A00
serial: <superuser required> UEFI: Alienware v: 1.20.0 date: 09/02/2022
ID-1: BAT1 charge: 74.5 Wh (100.0%) condition: 74.5/86.0 Wh (86.7%)
volts: 12.6 min: 11.4 model: COMPAL PABAS0241231 type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm
family: 6 model-id: 0xA5 (165) stepping: 2 microcode: 0xF0
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3069 high: 4853 min/max: 800/5000 scaling:
driver: intel_pstate governor: performance cores: 1: 2600 2: 2600 3: 1585
4: 2600 5: 2600 6: 4853 7: 2600 8: 4791 9: 4800 10: 2600 11: 2600
12: 2600 bogomips: 62399
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Dell driver: i915
v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0380
Device-2: NVIDIA TU104M [GeForce RTX 2070 SUPER Mobile / Max-Q]
vendor: Dell driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm
non-free: 515.xx+ status: current (as of 2022-10) arch: Turing
code: TUxxx process: TSMC 12nm built: 2018-22 pcie: gen: 3 speed: 8 GT/s
lanes: 8 link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1e91
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-7:3 chip-ID: 0bda:5538 class-ID: 0e02 serial: <filter>
Device-4: Realtek Cable Matters USB-C Video type: USB driver: N/A
bus-ID: 11-2:2 chip-ID: 0bda:5442 class-ID: 1100 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.4
compositor: kwin_x11 driver: X: loaded: nvidia gpu: i915,nvidia
Screen-1: 0 s-res: 4480x1440 s-dpi: 93 s-size: 1222x393mm (48.11x15.47")
s-diag: 1284mm (50.54")
Monitor-1: DP-0 pos: primary res: 2560x1440 dpi: 93
size: 697x392mm (27.44x15.43") diag: 800mm (31.48") modes: N/A
Monitor-2: DP-2 size-res: N/A modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 2070 Super/PCIe/SSE2 v: 4.6.0 NVIDIA
520.56.06 direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 5-2:2 chip-ID: 2188:6533
class-ID: 0300 chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA TU104 HD Audio vendor: Dell driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:10f8 class-ID: 0403
Device-3: No brand CalDigit Thunderbolt 3 Audio type: USB
Device-4: SteelSeries ApS Arctis Pro Wireless type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 7-1.3:5 chip-ID: 1038:1297
Device-1: Intel I210 Gigabit Network vendor: CalDigit driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 7000 bus-ID: 0b:00.0
chip-ID: 8086:1533 class-ID: 0200
IF: enp11s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek Killer E3000 2.5GbE vendor: Dell driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 3e:00.0
chip-ID: 10ec:3000 class-ID: 0200
IF: enp62s0 state: down mac: <filter>
Device-3: Intel Wi-Fi 6 AX200 vendor: Rivet Networks driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 3f:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp63s0 state: down mac: <filter>
bus-ID: 1-14:5 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 5.01 TiB used: 214.93 GiB (4.2%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Samsung model: SSD 980 1TB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B4QFXO7
temp: 44.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: KIOXIA model: KXG60ZNV512G NVMe
512GB size: 476.94 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 10604106
temp: 53.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 type: USB vendor: Seagate
model: ST4000LM024-2AN17V size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B type: HDD rpm: 5526 serial: <filter> rev: 0003 scheme: GPT
ID-1: / raw-size: 914.3 GiB size: 914.3 GiB (100.00%) used: 214.93 GiB
(23.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:6
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 596 KiB
(0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:5
ID-3: /home raw-size: 914.3 GiB size: 914.3 GiB (100.00%) used: 214.93
GiB (23.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:6
ID-4: /var/log raw-size: 914.3 GiB size: 914.3 GiB (100.00%) used: 214.93
ID-5: /var/tmp raw-size: 914.3 GiB size: 914.3 GiB (100.00%) used: 214.93
ID-1: swap-1 type: zram size: 15.38 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.92 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:7
System Temperatures: cpu: 62.0 C pch: 69.0 C mobo: N/A gpu: nvidia
temp: 49 C
Processes: 348 Uptime: 14m wakeups: 4 Memory: 15.38 GiB used: 5.7 GiB
(37.1%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 2244
libs: 570 tools: octopi,paru pm: flatpak pkgs: 0 Shell: fish v: 3.5.1
Garuda (2.6.8-1):
System install date: 2022-05-08
Last full system update: 2022-10-20
