Kernel: 6.2.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=fa6b5459-815a-4f95-bf19-d16dab40df60 rw [email protected]
resume=UUID=97b63a33-52e9-4a27-8dc3-680285f45aeb loglevel=3 ibt=off
Type: Laptop System: HP product: HP Notebook v: Type1ProductConfigId
Mobo: HP model: 80C2 v: 96.51 serial: <superuser required> UEFI: Insyde
v: F.27 date: 07/05/2018
Info: model: Intel Core i5-5200U bits: 64 type: MT MCP arch: Broadwell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1124 high: 2700 min/max: 500/2700 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2700 2: 500 3: 500
4: 798 bogomips: 17558
Device-1: Intel HD Graphics 5500 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-8 process: Intel 14nm built: 2014-15 ports:
active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1616
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 M430 Radeon
520 Mobile] vendor: Hewlett-Packard driver: radeon v: kernel
alternate: amdgpu arch: GCN-1 code: Southern Islands process: TSMC 28nm
built: 2011-20 pcie: gen: 2 speed: 5 GT/s lanes: 4 link-max: gen: 3
speed: 8 GT/s lanes: 8 bus-ID: 0d:00.0 chip-ID: 1002:6660 class-ID: 0380
temp: 52.0 C
Device-3: Chicony HP Truevision HD type: USB driver: uvcvideo
bus-ID: 1-5:5 chip-ID: 04f2:b509 class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: modesetting,radeon
alternate: fbdev,intel,vesa dri: iris,radeonsi gpu: i915 display-ID: :0
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: BOE Display 0x0808 built: 2018 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel HD Graphics 5500 (BDW
GT2) direct-render: Yes
Device-1: Intel Broadwell-U Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c
chip-ID: 8086:9ca0 class-ID: 0403
API: ALSA v: k6.2.10-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.68 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 5000
bus-ID: 07:00.0 chip-ID: 10ec:8136 class-ID: 0200
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtl8723be v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 13:00.0 chip-ID: 10ec:b723
IF: wlp19s0 state: up mac: <filter>
bus-ID: 1-4:4 chip-ID: 0bda:b006 class-ID: e001 serial: <filter>
address: <filter>
Local Storage: total: 989.25 GiB used: 41.18 GiB (4.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD100
type: HDD rpm: 5400 serial: <filter> rev: 2C scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Kingston
model: DataTraveler 3.0 size: 57.73 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 0000 scheme: MBR
ID-1: / raw-size: 922.42 GiB size: 922.42 GiB (100.00%)
used: 41.18 GiB (4.5%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 922.42 GiB size: 922.42 GiB (100.00%)
ID-4: /var/log raw-size: 922.42 GiB size: 922.42 GiB (100.00%)
ID-5: /var/tmp raw-size: 922.42 GiB size: 922.42 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.68 GiB used: 573 MiB (7.3%) priority: 100
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 60.0 C pch: 52.0 C mobo: N/A gpu: radeon
temp: 52.0 C
Processes: 233 Uptime: 6h 21m wakeups: 6 Memory: 7.68 GiB
used: 3.18 GiB (41.4%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1533
libs: 479 tools: octopi,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
System install date: 2023-04-13
Last full system update: 2023-04-13 ↻
Failed units: nmb.service systemd-vconsole-setup.service
ibus-setup is not opening what to do I want to add typing fonts if there is any other way to do it please tell
