Ibdisplay-info/gamescope -- dependency issues (sway/hyprland)
hi all,
think this is just an upstream issue but just flagging it FYI (not requesting anything to be done)
i like to use garuda gamer after doing full install/update after a freshinstall but now due to a depency issue with gamescope vs libdisplay-info - gamescope fails to install.
cli pacman install gamescope faces the same issue. I only had the issue initially on hyprland but now after reinstalling sway last few days its there too now.
This was the main reason i moved back from hypr to sway because seems i need gamescope for certain games :slight_smile:
Thanks guys your work is much appreciated as always
Please paste the terminal input and output into the thread if you are having an issue so we can take a look. Your garuda-inxi is missing as well.
The linked thread was solved, and the solution confirmed by the OP. Did you link the right thread?
Hi sorry here you go. I followed the solution provided in the previous thread but it did not work due to being a different problem i believe.
  Kernel: 6.6.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=97fc1713-d686-4bab-88d0-3a5155a481a3 rw rootflags=subvol=@
    quiet resume=UUID=3709ccc2-f003-4a43-bde7-81b0bdfd65cb loglevel=3 ibt=off
  Desktop: sway v: 1.8.1 info: waybar vt: 1 dm: greetd Distro: Garuda Linux
  Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK (MS-7C02) v: 1.0
    serial: <superuser required> UEFI: American Megatrends v: 1.E0
    date: 06/09/2020
    L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 3601 high: 3608 min/max: 2200/4208 boost: enabled
    scaling: driver: acpi-cpufreq governor: performance cores: 1: 3600 2: 3600
    3: 3600 4: 3600 5: 3600 6: 3600 7: 3608 8: 3605 9: 3608 10: 3600 11: 3600
    12: 3600 bogomips: 86397
    driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x process: TSMC n7 (7nm)
    built: 2019-20 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
    active: DP-1,DP-2,DP-3 empty: HDMI-A-1 bus-ID: 28:00.0 chip-ID: 1002:731f
  Display: wayland server: Xwayland v: 23.2.2 compositor: sway v: 1.8.1
    driver: gpu: amdgpu d-rect: 7040x2520 display-ID: 1
  Monitor-1: DP-1 pos: top-center model: VG27AQL1A serial: <filter>
    built: 2020 res: 2560x1440 hz: 144 dpi: 109 gamma: 1.2 scale: 1
    max: 2560x1440 min: 720x400
  Monitor-2: DP-2 pos: primary,top-left model: Samsung C27JG5x
    serial: <filter> built: 2018 res: 2560x1440 hz: 144 dpi: 109 gamma: 1.2
    scale: 1 size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
    modes: max: 2560x1440 min: 720x400
  Monitor-3: DP-3 pos: bottom-r model: Samsung LC27RG50 serial: <filter>
    built: 2020 res: 1920x1080 hz: 144 dpi: 92 gamma: 1.2 scale: 1
    size: 532x304mm (20.94x11.97") diag: 613mm (24.1") ratio: 16:9 modes:
    drv: radeonsi inactive: gbm
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 5700 XT (navi10 LLVM
    16.0.6 DRM 3.54 6.6.2-zen1-1-zen) device-ID: 1002:731f memory: 7.81 GiB
    unified: no
  API: Vulkan v: 1.3.269 layers: 10 device: 0 type: discrete-gpu name: AMD
    Radeon RX 5700 XT (RADV NAVI10) driver: mesa radv v: 23.2.1-arch1.2
    device-ID: 1002:731f surfaces: xcb,xlib,wayland device: 1 type: cpu
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 28:00.1 chip-ID: 1002:ab38
    bus-ID: 2a:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Corsair VOID ELITE Wireless Gaming Dongle
    lanes: 1 mode: 1.1 bus-ID: 3-2.3:5 chip-ID: 1b1c:0a51 class-ID: 0300
  API: ALSA v: k6.6.2-zen1-1-zen status: kernel-api tools: N/A
  Server-2: PipeWire v: 0.3.85 status: active with: 1: pipewire-pulse
  Device-1: Broadcom vendor: ASUSTeK driver: brcmfmac v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: N/A bus-ID: 21:00.0 chip-ID: 14e4:43c3
  Local Storage: total: 1.33 TiB used: 406.86 GiB (29.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Patriot model: Burst size: 894.25 GiB
    serial: <filter> fw-rev: 61.3 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 500GB
  ID-1: / raw-size: 876.84 GiB size: 876.84 GiB (100.00%)
    used: 12.2 GiB (1.4%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
  ID-3: /home raw-size: 876.84 GiB size: 876.84 GiB (100.00%)
  ID-4: /var/log raw-size: 876.84 GiB size: 876.84 GiB (100.00%)
  ID-5: /var/tmp raw-size: 876.84 GiB size: 876.84 GiB (100.00%)
  ID-1: swap-1 type: zram size: 15.56 GiB used: 0 KiB (0.0%) priority: 100
  ID-2: swap-2 type: partition size: 17.12 GiB used: 0 KiB (0.0%)
  System Temperatures: cpu: 36.5 C mobo: N/A gpu: amdgpu temp: 35.0 C
    mem: 42.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 1128
  Processes: 387 Uptime: 1m wakeups: 0 Memory: total: 16 GiB
  available: 15.56 GiB used: 1.96 GiB (12.6%) Init: systemd v: 254
  pm: pacman pkgs: 1448 libs: 451 tools: pamac,paru Shell: fish v: 3.6.1
  running-in: alacritty inxi: 3.3.31
Garuda (2.6.19-2):
  System install date:     2023-11-26
  Last full system update: 2023-11-26
Paste the terminal output into the thread so we can take a look.
 ╰─λ sudo pacman -S gamescope-git
[sudo] password for ben:
resolving dependencies...
Package (3)                New Version           Net Change
extra/benchmark            1.8.3-1                 0.58 MiB
extra/libxres              1.2.2-1                 0.02 MiB
chaotic-aur/gamescope-git  3.13.8.r2.ge384c4e-1    4.50 MiB
Total Installed Size:  5.10 MiB
(3/3) checking keys in keyring        [-------------------------------------------------------] 100%
(3/3) checking package integrity                                                              [-------------------------------------------------------] 100%
(3/3) loading package files        [-------------------------------------------------------] 100%
(3/3) checking for file conflicts                                                             [-------------------------------------------------------] 100%
gamescope-git: /usr/bin/di-edid-decode exists in filesystem (owned by libdisplay-info)
Hmm, you said it was a different issue than the other thread but it looks like the same one.
Try to overwrite the problematic file during the update:
garuda-update -- --overwrite /usr/bin/di-edid-decode
hi Bluish,
Thanks you put me on the right track. Solved with the below.
sudo pacman -S gamescope-git --overwrite /usr/bin/di-edid-decode
