Hello! I installed Garuda I3 distro and got this problem from the very beginning. At first, if I choose ru locale on the installation stage, I can't even run Garuda settings or assistant, cause I can't switch languages. Also the I3 does not react Cyrillic keys. If I choose US locale as default, I still have problems.
There is no way to set lang-change keybindings in default settings gui. So each time I have to:
- run default settings gui -> keyboard settings
- Switch to russian and back
setxkbmap -layout us, ru
setxkbmap -option 'grp:alt_shift_toggle'
Putting this scripts into . bashrc . zshrc gives no result after reboot.
Configuring /etc/locale.conf and
locale-gen gives no result.
Configuring /etc/vconsole.conf and reboot gives no result.
Also default keybindings for i3 from the box are not good, because traditionaly i3 used to be exploiting jkl; for changins focus/size rather than arrows - it is much handy after all.
Laptop: Fudjitsu Lifebook e780
Distro: Garuda I3wm.
