Hi everyone, I have used Linux Mint for the past 18 months. This is my first adventure outside of Mint and the trigger for this was finding out about the Gnome desktop environment.
My problem with the install is this step in the install procedure
"Make sure that your device's SATA controller is set to AHCI mode in your device's setup utility. Otherwise, the Linux kernel may not be able to detect your drive."
I can not find how to confirm/change this setting which makes me unsureif my laptop is compatible. I have put the details of my laptop into the registration form if that helps
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_NZ keytable=us tz=UTC
misobasedir=garuda misolabel=GARUDA_GNOME_TALON quiet
systemd.show_status=1 ibt=off driver=free nouveau.modeset=1
Desktop: GNOME v: 42.5 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Laptop System: HP product: HP ProBook 430 G7 v: N/A
Mobo: HP model: 869B v: KBC Version 02.38.00 serial: <superuser required>
UEFI: HP v: S71 Ver. 01.13.01 date: 06/23/2022
ID-1: BAT0 charge: 8.9 Wh (28.9%) condition: 30.8/45.2 Wh (68.0%)
volts: 10.5 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: discharging cycles: 145
Info: model: Intel Core i5-10210U bits: 64 type: MT MCP
stepping: 0xC (12) microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1450 high: 2100 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 2100
4: 800 5: 2100 6: 2100 7: 2100 8: 800 bogomips: 33599
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Hewlett-Packard
Device-2: Luxvisions Innotech HP HD Camera type: USB driver: uvcvideo
bus-ID: 1-2:2 chip-ID: 30c9:0009 class-ID: 0e02 serial: <filter>
compositor: gnome-shell driver: X: loaded: modesetting
Monitor-1: eDP-1 model: BOE Display 0x08a6 built: 2019 res: 1920x1080
hz: 60 dpi: 166 gamma: 1.2 size: 294x165mm (11.57x6.5") diag: 337mm (13.3")
ratio: 16:9 modes: 1920x1080
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard
driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0401
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168
bus-ID: 1-10:5 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 252.94 GiB used: 0 KiB (0.0%)
model: MZVLQ256HAJD-000H1 size: 238.47 GiB block-size: physical: 512 B
rev: HPS4NFXV temp: 13.8 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Verbatim model: STORE N GO
size: 14.47 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: PMAP scheme: MBR
ID-1: swap-1 type: zram size: 7.6 GiB used: 283 MiB (3.6%) priority: 100
System Temperatures: cpu: 43.0 C pch: 41.0 C mobo: N/A
Processes: 248 Uptime: 14m wakeups: 1 Memory: 7.6 GiB used: 2.63 GiB
(34.6%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1134 libs: 314
tools: pamac,paru Shell: fish v: 3.5.1 default: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.22
Garuda (2.6.8-1):
System install date: 2022-12-15
Last full system update: 2022-12-15 ↻
