while using dolphin the first time, i accidentally got rid of all the shortcuts, and now i can't find the recycle bin. how do I get the shortcuts back? please help my storage is half-way full.
Hi there, welcome to forums.
Which shortcuts?
Its name is trash.
on the side-bar there were a few shortcuts, the desktop, downloads, basically anything in the home folder was there. there was also the trash bin, which i cannot find elsewhere
Simply open dolphin and close all tabs (using ctrl+ w or with cross icon)
Now, open dolphin again (from application menu) and you are in home folder.
You can now find trash there.
i might just be blind, but i can't seem to find the trash folder within the home folder. I tried ctrl+w, and i have also enabled hidden folders
Wait, I will turn on my pc. Maybe, I am forgetting something.
So, yep, trash in not in home (Home is clean )
Now, all you have to do is at desktop, right click and add widget, trash.
You will get trashcan widget on desktop itself.
thank you.
storage has finally been restored
