I installed obs studio using flatpak package manager . It won't record mic audio, it records fine with desktop audio
I am new to garuda linux , Just migrated from windows I tried installing obs studio with flatpak pacakage manager . It records video without any hassle. But it won't record mic audio . But it does record Desktop audio. Similar problem of not recording mic audio was encountered when I installed audacity.
Please post the output from garuda-inxi like the post template says. It gives us the information we need to help.
Just use
sudo pacman -Syu obs-studio
flatpak are not supported by Garuda Linux, ask the upstream developer, please.
BTW, Garuda Linux forum isn’t a general technical support forum.
At all.
Refusing to post the output of the required “garuda-inxi” on a help request will likely result in you not receiving any help from the Garuda team. A failure to provide your system specs may also result in your thread being closed without notice,
Thanks it worked
