I have problem with writing data in / directory and the mounted device at run/media/"deviceName"
garuda-inix command:
Kernel: 6.6.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=eadc67aa-659a-4064-bc6f-02c372fc8405 rw rootflags=subvol=@
resume=UUID=68618af3-01d9-4ad2-9740-27ade4547148 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 info: docker wm: kwin_x11
vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: ASRock model: A520M-HVS serial: <superuser required>
UEFI: American Megatrends LLC. v: P3.00 date: 06/29/2023
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701030
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3619 high: 3906 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3600 2: 3600
3: 3906 4: 3559 5: 3593 6: 3600 7: 3577 8: 3600 9: 3600 10: 3593 11: 3600
12: 3600 bogomips: 86239
Device-1: AMD Navi 14 [Radeon RX 5500/5500M / Pro 5500M] vendor: ASRock
driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x process: TSMC n7 (7nm)
built: 2019-20 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-3
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 07:00.0 chip-ID: 1002:7340
Monitor-1: DP-3 mapped: DisplayPort-2 model: AOC G2490W1G4
serial: <filter> built: 2021 res: 1920x1080 dpi: 93 gamma: 1.2
inactive: gbm,wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 5500 XT (navi14 LLVM
16.0.6 DRM 3.54 6.6.2-zen1-1-zen) device-ID: 1002:7340 memory: 7.81 GiB
unified: no
API: Vulkan v: 1.3.269 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 5500 XT (RADV NAVI14) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:7340 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: AMD Navi 10 HDMI Audio vendor: ASRock driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 07:00.1
chip-ID: 1002:ab38 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.6.2-zen1-1-zen status: kernel-api with: aoss
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Ralink MT7601U Wireless Adapter driver: mt7601u type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:4 chip-ID: 148f:7601
IF: wlp9s0f3u3 state: up mac: <filter>
Local Storage: total: 1.95 TiB used: 972.29 GiB (48.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lexar model: 512GB SSD
lanes: 4 tech: SSD serial: <filter> fw-rev: V1.19.B3 temp: 43.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 120GB
size: 111.8 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 00RL scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Hikvision model: HS-SSD-E100 512G
tech: SSD serial: <filter> fw-rev: 18B2 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Toshiba model: MQ04ABF100
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: HDD rpm: 5400
serial: <filter> fw-rev: 1.14 scheme: MBR
ID-1: / raw-size: 94.41 GiB size: 94.41 GiB (100.00%) used: 83.3 GiB (88.2%)
ID-3: /home raw-size: 94.41 GiB size: 94.41 GiB (100.00%)
used: 83.3 GiB (88.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 94.41 GiB size: 94.41 GiB (100.00%)
ID-5: /var/tmp raw-size: 94.41 GiB size: 94.41 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.54 GiB used: 447.8 MiB (2.8%)
ID-2: swap-2 type: partition size: 17.09 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 57.8 C mobo: N/A gpu: amdgpu temp: 50.0 C
mem: 0.0 C
Processes: 445 Uptime: 36m wakeups: 0 Memory: total: 16 GiB
available: 15.54 GiB used: 5.27 GiB (33.9%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1982
pm: pacman pkgs: 1963 libs: 568 tools: gnome-software,octopi,pamac,paru,yay
pm: appimage pkgs: 0 pm: flatpak pkgs: 19 Shell: fish v: 3.6.1 default: Bash
v: 5.2.15 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
System install date:     2023-09-18
Last full system update: 2023-11-22
the problem is that I can only create folders using sudo, although I was able to do that using Dolphin Explorer before!
I don’t remember that I made any changes and all permissions are the defaults
the Create New and Delete buttons are disabled in the dolphin in / directory and mounted devices
Because of security issues, Dolphin (and most Plasma apps) don’t support root access as they once did.
sudo mkdir and sudo chmod ride to the rescue :slightly_smiling_face:
Install kio-admin and you can perform several root actions.
You need to take ownership of the drive (chown) to access it as a user (not root).
The thing that I was able to write on any device and write in / directory using Dolphin, that was just 2 days ago, and if I needed to write Dolphin prompted me for the password for the root
another thing that when I was mounting my hard drive in /run/media/[myusername]/[hard Drive]
I was able to read and write without even the root action, this was the default Garuda settings
Some people said that it is because of the dual boot with Windows, and the fast boot option, I disable the fast boot in Windows and still can’t edit write, or read.
I tried another solution which is giving the permissions to the host I used
sudo chmod 777 / and still can do any write or editing actions!
I did chmod on the hard drive but it did not work
I have even tried sudo chmod 777 / and it did not work
now I made a big mistake by running sudo chmod -R 777 /
Ya, that’s never a good idea.
is there any solution for that ?
Depends on what was on the drive and what the file system is.
If it was a Windows NTFS drive only used for storage no big deal.
On your / root operating system partition that’s likely totally messed, recover any data you need and start fresh again.
This command may help:
 sudo chmod -R u+rwX,go+rX,go-w /
But lots of permissions will still be incorrect.
the good think is that windows hard drive was unmounted , but my problem now is with garuda in the / root
so now I need to reinstall the system right ?
if yes then can I get a clone of the apps and configuration files
╭─splitech@splitech in ~ took 1ms
[🔴] × sudo chmod -R u+rwX,go+rX,go-w /
sudo: /etc/sudo.conf is world writable
sudo: /usr/bin/sudo must be owned by uid 0 and have the setuid bit set
yup denied
You can get a list of installed packages with pacman and make duplicates of any config files/directories you want.
That would be best attempted from a live disk I’d think.
╭─splitech@splitech in ~ took 42ms
╰─λ sudo chmod -R u+rwX,go+rX,go-w /
denied, well I guess I need to reinstall the system.
Thanks sir for your help much appreciated:pray:
Sudo is borked, but you likely can still run commands as root using su.
I reinstall the system, thanks for garuda assistance I was up and running too fast !
but I face a new problem whenever I mount the hard drive this is what I get:
An error occurred while accessing ‘931.5 GiB Removable Media’, the system responded: The requested operation has failed: Error mounting /dev/sdc1 at /run/media/splitech/E4D8CDE0D8CDB0DA: wrong fs type, bad option, bad superblock on /dev/sdc1, missing codepage or helper program, or other error
what I have done is this
sudo pacman -S ntfs-3g
but still the same error , I tried to mount using commands with sudo but I got this
sudo mount /dev/sdc
mount: /dev/sdc: can’t find in /etc/fstab.
the hard drive working fine with windows and it was working fine before reinstalling the system !
Can you share the output of
lsblk -f
and
sudo dmesg
after the error happens when you try to mount the drive.
it is ntfs
╭─splitech@splitech in ~ as 🧙 took 26ms
╰─λ lsblk -f
NAME        FSTYPE FSVER LABEL UUID                                 FSAVAIL FSUSE% MOUNTPOINTS
sda
├─sda1      vfat   FAT32       F426-E2D0                             298.8M     0% /boot/efi
├─sda2      btrfs              b053ec43-6873-436a-986d-03bf1fa161c0   73.1G    22% /var/log
│        /var/cache
│        /var/tmp
│        /srv
│        /root
│        /home
└─sda3      swap   1     swap  b611321b-cd44-4aa4-9d14-38a438e5e338                [SWAP]
sdb
├─sdb1      vfat   FAT32       2E4B-6110
├─sdb2
└─sdb3      ntfs               01DA150705C8A1C0
sdc
└─sdc1      ntfs               E4D8CDE0D8CDB0DA
zram0        [SWAP]
nvme0n1
├─nvme0n1p1 vfat   FAT32       F2E0-4CD1
├─nvme0n1p2
├─nvme0n1p3 ntfs               A622E11C22E0F1EB
└─nvme0n1p4 ntfs               C086C50886C50040
for sudo demsg
[    0.234493] PCI: MMCONFIG for domain 0000 [bus 00-7f] at [mem 0xf0000000-0xf7ffffff] (base 0xf0000000)
[    0.234498] PCI: not using MMCONFIG
[    0.234499] PCI: Using configuration type 1 for base access
[    0.234500] PCI: Using configuration type 1 for extended access
[    0.235559] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[    0.235565] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.235565] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[    0.235565] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.235565] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[    0.235565] ACPI: Added _OSI(Module Device)
[    0.235565] ACPI: Added _OSI(Processor Device)
[    0.235565] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.235565] ACPI: Added _OSI(Processor Aggregator Device)
[    0.250780] ACPI: 12 ACPI AML tables successfully acquired and loaded
[    0.253071] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.254843] ACPI: _OSC evaluation for CPUs failed, trying _PDC
[    0.256392] ACPI: Interpreter enabled
[    0.256409] ACPI: PM: (supports S0 S3 S4 S5)
[    0.256410] ACPI: Using IOAPIC for interrupt routing
[    0.257873] PCI: MMCONFIG for domain 0000 [bus 00-7f] at [mem 0xf0000000-0xf7ffffff] (base 0xf0000000)
[    0.257930] PCI: MMCONFIG at [mem 0xf0000000-0xf7ffffff] reserved as ACPI motherboard resource
[    0.257939] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.257940] PCI: Ignoring E820 reservations for host bridge windows
[    0.258557] ACPI: Enabled 8 GPEs in block 00 to 1F
[    0.273705] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.273711] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[    0.273853] acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug LTR DPC]
[    0.274114] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
[    0.274125] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-7f] only partially covers this bridge
[    0.274857] PCI host bridge to bus 0000:00
[    0.274858] pci_bus 0000:00: root bus resource [io  0x0000-0x03af window]
[    0.274860] pci_bus 0000:00: root bus resource [io  0x03e0-0x0cf7 window]
[    0.274862] pci_bus 0000:00: root bus resource [io  0x03b0-0x03df window]
[    0.274864] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.274866] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000dffff window]
[    0.274867] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xfec2ffff window]
[    0.274869] pci_bus 0000:00: root bus resource [mem 0xfee00000-0xffffffff window]
[    0.274871] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.274890] pci 0000:00:00.0: [1022:1480] type 00 class 0x060000
[    0.275006] pci 0000:00:01.0: [1022:1482] type 00 class 0x060000
[    0.275076] pci 0000:00:01.1: [1022:1483] type 01 class 0x060400
[    0.275107] pci 0000:00:01.1: enabling Extended Tags
[    0.275161] pci 0000:00:01.1: PME# supported from D0 D3hot D3cold
[    0.275323] pci 0000:00:01.2: [1022:1483] type 01 class 0x060400
[    0.275354] pci 0000:00:01.2: enabling Extended Tags
[    0.275407] pci 0000:00:01.2: PME# supported from D0 D3hot D3cold
[    0.275608] pci 0000:00:02.0: [1022:1482] type 00 class 0x060000
[    0.275678] pci 0000:00:03.0: [1022:1482] type 00 class 0x060000
[    0.275745] pci 0000:00:03.1: [1022:1483] type 01 class 0x060400
[    0.275815] pci 0000:00:03.1: PME# supported from D0 D3hot D3cold
[    0.275965] pci 0000:00:04.0: [1022:1482] type 00 class 0x060000
[    0.276035] pci 0000:00:05.0: [1022:1482] type 00 class 0x060000
[    0.276105] pci 0000:00:07.0: [1022:1482] type 00 class 0x060000
[    0.276171] pci 0000:00:07.1: [1022:1484] type 01 class 0x060400
[    0.276197] pci 0000:00:07.1: enabling Extended Tags
[    0.276240] pci 0000:00:07.1: PME# supported from D0 D3hot D3cold
[    0.276379] pci 0000:00:08.0: [1022:1482] type 00 class 0x060000
[    0.276446] pci 0000:00:08.1: [1022:1484] type 01 class 0x060400
[    0.276473] pci 0000:00:08.1: enabling Extended Tags
[    0.276519] pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
[    0.276689] pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500
[    0.276822] pci 0000:00:14.3: [1022:790e] type 00 class 0x060100
[    0.276974] pci 0000:00:18.0: [1022:1440] type 00 class 0x060000
[    0.277013] pci 0000:00:18.1: [1022:1441] type 00 class 0x060000
[    0.277052] pci 0000:00:18.2: [1022:1442] type 00 class 0x060000
[    0.277091] pci 0000:00:18.3: [1022:1443] type 00 class 0x060000
[    0.277131] pci 0000:00:18.4: [1022:1444] type 00 class 0x060000
[    0.277170] pci 0000:00:18.5: [1022:1445] type 00 class 0x060000
[    0.277210] pci 0000:00:18.6: [1022:1446] type 00 class 0x060000
[    0.277249] pci 0000:00:18.7: [1022:1447] type 00 class 0x060000
[    0.277507] pci 0000:01:00.0: [1d97:5216] type 00 class 0x010802
[    0.277527] pci 0000:01:00.0: reg 0x10: [mem 0xfcf20000-0xfcf23fff 64bit]
[    0.277564] pci 0000:01:00.0: reg 0x30: [mem 0xfcf00000-0xfcf1ffff pref]
[    0.277782] pci 0000:00:01.1: PCI bridge to [bus 01]
[    0.277788] pci 0000:00:01.1:   bridge window [mem 0xfcf00000-0xfcffffff]
[    0.277867] pci 0000:02:00.0: [1022:43ec] type 00 class 0x0c0330
[    0.277887] pci 0000:02:00.0: reg 0x10: [mem 0xfcea0000-0xfcea7fff 64bit]
[    0.277932] pci 0000:02:00.0: enabling Extended Tags
[    0.277990] pci 0000:02:00.0: PME# supported from D3hot D3cold
[    0.278159] pci 0000:02:00.1: [1022:43eb] type 00 class 0x010601
[    0.278213] pci 0000:02:00.1: reg 0x24: [mem 0xfce80000-0xfce9ffff]
[    0.278222] pci 0000:02:00.1: reg 0x30: [mem 0xfce00000-0xfce7ffff pref]
[    0.278230] pci 0000:02:00.1: enabling Extended Tags
[    0.278278] pci 0000:02:00.1: PME# supported from D3hot D3cold
[    0.278389] pci 0000:02:00.2: [1022:43e9] type 01 class 0x060400
[    0.278439] pci 0000:02:00.2: enabling Extended Tags
[    0.278493] pci 0000:02:00.2: PME# supported from D3hot D3cold
[    0.278637] pci 0000:00:01.2: PCI bridge to [bus 02-04]
[    0.278642] pci 0000:00:01.2:   bridge window [io  0xf000-0xffff]
[    0.278644] pci 0000:00:01.2:   bridge window [mem 0xfcd00000-0xfcefffff]
[    0.278805] pci 0000:03:03.0: [1022:43ea] type 01 class 0x060400
[    0.278858] pci 0000:03:03.0: enabling Extended Tags
[    0.278924] pci 0000:03:03.0: PME# supported from D3hot D3cold
[    0.279071] pci 0000:02:00.2: PCI bridge to [bus 03-04]
[    0.279077] pci 0000:02:00.2:   bridge window [io  0xf000-0xffff]
[    0.279080] pci 0000:02:00.2:   bridge window [mem 0xfcd00000-0xfcdfffff]
[    0.279155] pci 0000:04:00.0: [10ec:8168] type 00 class 0x020000
[    0.279185] pci 0000:04:00.0: reg 0x10: [io  0xf000-0xf0ff]
[    0.279225] pci 0000:04:00.0: reg 0x18: [mem 0xfcd04000-0xfcd04fff 64bit]
[    0.279250] pci 0000:04:00.0: reg 0x20: [mem 0xfcd00000-0xfcd03fff 64bit]
[    0.279416] pci 0000:04:00.0: supports D1 D2
[    0.279417] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.279688] pci 0000:03:03.0: PCI bridge to [bus 04]
[    0.279694] pci 0000:03:03.0:   bridge window [io  0xf000-0xffff]
[    0.279697] pci 0000:03:03.0:   bridge window [mem 0xfcd00000-0xfcdfffff]
[    0.279780] pci 0000:05:00.0: [1002:1478] type 01 class 0x060400
[    0.279796] pci 0000:05:00.0: reg 0x10: [mem 0xfcc00000-0xfcc03fff]
[    0.279916] pci 0000:05:00.0: PME# supported from D0 D3hot D3cold
[    0.280008] pci 0000:05:00.0: 63.008 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x8 link at 0000:00:03.1 (capable of 126.024 Gb/s with 16.0 GT/s PCIe x8 link)
[    0.280154] pci 0000:00:03.1: PCI bridge to [bus 05-07]
[    0.280159] pci 0000:00:03.1:   bridge window [io  0xe000-0xefff]
[    0.280162] pci 0000:00:03.1:   bridge window [mem 0xfcb00000-0xfccfffff]
[    0.280165] pci 0000:00:03.1:   bridge window [mem 0xd0000000-0xe01fffff 64bit pref]
[    0.280242] pci 0000:06:00.0: [1002:1479] type 01 class 0x060400
[    0.280372] pci 0000:06:00.0: PME# supported from D0 D3hot D3cold
[    0.281315] pci 0000:05:00.0: PCI bridge to [bus 06-07]
[    0.281321] pci 0000:05:00.0:   bridge window [io  0xe000-0xefff]
[    0.281325] pci 0000:05:00.0:   bridge window [mem 0xfcb00000-0xfcbfffff]
[    0.281330] pci 0000:05:00.0:   bridge window [mem 0xd0000000-0xe01fffff 64bit pref]
[    0.281414] pci 0000:07:00.0: [1002:7340] type 00 class 0x030000
[    0.281434] pci 0000:07:00.0: reg 0x10: [mem 0xd0000000-0xdfffffff 64bit pref]
[    0.281447] pci 0000:07:00.0: reg 0x18: [mem 0xe0000000-0xe01fffff 64bit pref]
[    0.281456] pci 0000:07:00.0: reg 0x20: [io  0xe000-0xe0ff]
[    0.281465] pci 0000:07:00.0: reg 0x24: [mem 0xfcb00000-0xfcb7ffff]
[    0.281473] pci 0000:07:00.0: reg 0x30: [mem 0xfcb80000-0xfcb9ffff pref]
[    0.281507] pci 0000:07:00.0: BAR 0: assigned to efifb
[    0.281514] pci 0000:07:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.281596] pci 0000:07:00.0: PME# supported from D1 D2 D3hot D3cold
[    0.281697] pci 0000:07:00.0: 63.008 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x8 link at 0000:00:03.1 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[    0.281814] pci 0000:07:00.1: [1002:ab38] type 00 class 0x040300
[    0.281829] pci 0000:07:00.1: reg 0x10: [mem 0xfcba0000-0xfcba3fff]
[    0.281941] pci 0000:07:00.1: PME# supported from D1 D2 D3hot D3cold
[    0.282091] pci 0000:06:00.0: PCI bridge to [bus 07]
[    0.282097] pci 0000:06:00.0:   bridge window [io  0xe000-0xefff]
[    0.282100] pci 0000:06:00.0:   bridge window [mem 0xfcb00000-0xfcbfffff]
[    0.282106] pci 0000:06:00.0:   bridge window [mem 0xd0000000-0xe01fffff 64bit pref]
[    0.282169] pci 0000:08:00.0: [1022:148a] type 00 class 0x130000
[    0.282200] pci 0000:08:00.0: enabling Extended Tags
[    0.282370] pci 0000:00:07.1: PCI bridge to [bus 08]
[    0.282442] pci 0000:09:00.0: [1022:1485] type 00 class 0x130000
[    0.282477] pci 0000:09:00.0: enabling Extended Tags
[    0.282640] pci 0000:09:00.1: [1022:1486] type 00 class 0x108000
[    0.282657] pci 0000:09:00.1: reg 0x18: [mem 0xfc900000-0xfc9fffff]
[    0.282669] pci 0000:09:00.1: reg 0x24: [mem 0xfca08000-0xfca09fff]
[    0.282679] pci 0000:09:00.1: enabling Extended Tags
[    0.282814] pci 0000:09:00.3: [1022:149c] type 00 class 0x0c0330
[    0.282828] pci 0000:09:00.3: reg 0x10: [mem 0xfc800000-0xfc8fffff 64bit]
[    0.282859] pci 0000:09:00.3: enabling Extended Tags
[    0.282909] pci 0000:09:00.3: PME# supported from D0 D3hot D3cold
[    0.283038] pci 0000:09:00.4: [1022:1487] type 00 class 0x040300
[    0.283048] pci 0000:09:00.4: reg 0x10: [mem 0xfca00000-0xfca07fff]
[    0.283076] pci 0000:09:00.4: enabling Extended Tags
[    0.283122] pci 0000:09:00.4: PME# supported from D0 D3hot D3cold
[    0.283255] pci 0000:00:08.1: PCI bridge to [bus 09]
[    0.283260] pci 0000:00:08.1:   bridge window [mem 0xfc800000-0xfcafffff]
[    0.283912] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[    0.283989] ACPI: PCI: Interrupt link LNKB configured for IRQ 0
[    0.284057] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[    0.284140] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[    0.284216] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[    0.284281] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[    0.284346] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[    0.284408] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[    0.285587] iommu: Default domain type: Translated
[    0.285587] iommu: DMA domain TLB invalidation policy: lazy mode
[    0.285587] SCSI subsystem initialized
[    0.285587] libata version 3.00 loaded.
[    0.285587] ACPI: bus type USB registered
[    0.285587] usbcore: registered new interface driver usbfs
[    0.285587] usbcore: registered new interface driver hub
[    0.285587] usbcore: registered new device driver usb
[    0.285587] pps_core: LinuxPPS API ver. 1 registered
[    0.285587] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[    0.285587] PTP clock support registered
[    0.285587] EDAC MC: Ver: 3.0.0
[    0.285587] efivars: Registered efivars operations
[    0.286340] NetLabel: Initializing
[    0.286341] NetLabel:  domain hash size = 128
[    0.286342] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.286361] NetLabel:  unlabeled traffic allowed by default
[    0.286366] mctp: management component transport protocol core
[    0.286367] NET: Registered PF_MCTP protocol family
[    0.286371] PCI: Using ACPI for IRQ routing
[    0.290330] PCI: pci_cache_line_size set to 64 bytes
[    0.290394] e820: reserve RAM buffer [mem 0x09bff000-0x0bffffff]
[    0.290396] e820: reserve RAM buffer [mem 0x0a200000-0x0bffffff]
[    0.290397] e820: reserve RAM buffer [mem 0x0b000000-0x0bffffff]
[    0.290398] e820: reserve RAM buffer [mem 0xa8fcf018-0xabffffff]
[    0.290400] e820: reserve RAM buffer [mem 0xb6fc6000-0xb7ffffff]
[    0.290401] e820: reserve RAM buffer [mem 0xba7a6000-0xbbffffff]
[    0.290402] e820: reserve RAM buffer [mem 0xbb228000-0xbbffffff]
[    0.290403] e820: reserve RAM buffer [mem 0xbf000000-0xbfffffff]
[    0.290404] e820: reserve RAM buffer [mem 0x43f380000-0x43fffffff]
[    0.290475] pci 0000:07:00.0: vgaarb: setting as boot VGA device
[    0.290475] pci 0000:07:00.0: vgaarb: bridge control possible
[    0.290475] pci 0000:07:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.290475] vgaarb: loaded
[    0.290475] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[    0.290475] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[    0.292377] clocksource: Switched to clocksource tsc-early
[    0.295612] VFS: Disk quotas dquot_6.6.0
[    0.295628] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.295698] pnp: PnP ACPI init
[    0.295800] system 00:00: [mem 0xf0000000-0xf7ffffff] has been reserved
[    0.295851] system 00:01: [mem 0xfeb80000-0xfebfffff] has been reserved
[    0.295946] system 00:02: [mem 0xfd200000-0xfd2fffff] has been reserved
[    0.296270] system 00:04: [io  0x0280-0x028f] has been reserved
[    0.296272] system 00:04: [io  0x0290-0x029f] has been reserved
[    0.296274] system 00:04: [io  0x02a0-0x02af] has been reserved
[    0.296275] system 00:04: [io  0x02b0-0x02bf] has been reserved
[    0.296615] pnp 00:05: [dma 0 disabled]
[    0.297019] system 00:06: [io  0x04d0-0x04d1] has been reserved
[    0.297022] system 00:06: [io  0x040b] has been reserved
[    0.297023] system 00:06: [io  0x04d6] has been reserved
[    0.297025] system 00:06: [io  0x0c00-0x0c01] has been reserved
[    0.297027] system 00:06: [io  0x0c14] has been reserved
[    0.297028] system 00:06: [io  0x0c50-0x0c51] has been reserved
[    0.297030] system 00:06: [io  0x0c52] has been reserved
[    0.297032] system 00:06: [io  0x0c6c] has been reserved
[    0.297033] system 00:06: [io  0x0c6f] has been reserved
[    0.297035] system 00:06: [io  0x0cd8-0x0cdf] has been reserved
[    0.297037] system 00:06: [io  0x0800-0x089f] has been reserved
[    0.297038] system 00:06: [io  0x0b00-0x0b0f] has been reserved
[    0.297040] system 00:06: [io  0x0b20-0x0b3f] has been reserved
[    0.297042] system 00:06: [io  0x0900-0x090f] has been reserved
[    0.297043] system 00:06: [io  0x0910-0x091f] has been reserved
[    0.297046] system 00:06: [mem 0xfec00000-0xfec00fff] could not be reserved
[    0.297048] system 00:06: [mem 0xfec01000-0xfec01fff] could not be reserved
[    0.297050] system 00:06: [mem 0xfedc0000-0xfedc0fff] has been reserved
[    0.297053] system 00:06: [mem 0xfee00000-0xfee00fff] has been reserved
[    0.297054] system 00:06: [mem 0xfed80000-0xfed8ffff] could not be reserved
[    0.297057] system 00:06: [mem 0xfec10000-0xfec10fff] has been reserved
[    0.297059] system 00:06: [mem 0xff000000-0xffffffff] has been reserved
[    0.297921] pnp: PnP ACPI: found 7 devices
[    0.303667] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.303748] NET: Registered PF_INET protocol family
[    0.303876] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.306072] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.306095] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.306148] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.306356] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    0.306438] TCP: Hash tables configured (established 131072 bind 65536)
[    0.306538] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
[    0.306578] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.306610] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.306683] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.306690] NET: Registered PF_XDP protocol family
[    0.306701] pci 0000:00:01.1: PCI bridge to [bus 01]
[    0.306705] pci 0000:00:01.1:   bridge window [mem 0xfcf00000-0xfcffffff]
[    0.306712] pci 0000:03:03.0: PCI bridge to [bus 04]
[    0.306714] pci 0000:03:03.0:   bridge window [io  0xf000-0xffff]
[    0.306719] pci 0000:03:03.0:   bridge window [mem 0xfcd00000-0xfcdfffff]
[    0.306727] pci 0000:02:00.2: PCI bridge to [bus 03-04]
[    0.306730] pci 0000:02:00.2:   bridge window [io  0xf000-0xffff]
[    0.306735] pci 0000:02:00.2:   bridge window [mem 0xfcd00000-0xfcdfffff]
[    0.306742] pci 0000:00:01.2: PCI bridge to [bus 02-04]
[    0.306745] pci 0000:00:01.2:   bridge window [io  0xf000-0xffff]
[    0.306748] pci 0000:00:01.2:   bridge window [mem 0xfcd00000-0xfcefffff]
[    0.306755] pci 0000:06:00.0: PCI bridge to [bus 07]
[    0.306757] pci 0000:06:00.0:   bridge window [io  0xe000-0xefff]
[    0.306761] pci 0000:06:00.0:   bridge window [mem 0xfcb00000-0xfcbfffff]
[    0.306765] pci 0000:06:00.0:   bridge window [mem 0xd0000000-0xe01fffff 64bit pref]
[    0.306771] pci 0000:05:00.0: PCI bridge to [bus 06-07]
[    0.306773] pci 0000:05:00.0:   bridge window [io  0xe000-0xefff]
[    0.306778] pci 0000:05:00.0:   bridge window [mem 0xfcb00000-0xfcbfffff]
[    0.306781] pci 0000:05:00.0:   bridge window [mem 0xd0000000-0xe01fffff 64bit pref]
[    0.306787] pci 0000:00:03.1: PCI bridge to [bus 05-07]
[    0.306789] pci 0000:00:03.1:   bridge window [io  0xe000-0xefff]
[    0.306792] pci 0000:00:03.1:   bridge window [mem 0xfcb00000-0xfccfffff]
[    0.306795] pci 0000:00:03.1:   bridge window [mem 0xd0000000-0xe01fffff 64bit pref]
[    0.306800] pci 0000:00:07.1: PCI bridge to [bus 08]
[    0.306808] pci 0000:00:08.1: PCI bridge to [bus 09]
[    0.306811] pci 0000:00:08.1:   bridge window [mem 0xfc800000-0xfcafffff]
[    0.306817] pci_bus 0000:00: resource 4 [io  0x0000-0x03af window]
[    0.306819] pci_bus 0000:00: resource 5 [io  0x03e0-0x0cf7 window]
[    0.306821] pci_bus 0000:00: resource 6 [io  0x03b0-0x03df window]
[    0.306823] pci_bus 0000:00: resource 7 [io  0x0d00-0xffff window]
[    0.306825] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000dffff window]
[    0.306826] pci_bus 0000:00: resource 9 [mem 0xc0000000-0xfec2ffff window]
[    0.306828] pci_bus 0000:00: resource 10 [mem 0xfee00000-0xffffffff window]
[    0.306830] pci_bus 0000:01: resource 1 [mem 0xfcf00000-0xfcffffff]
[    0.306842] pci_bus 0000:02: resource 0 [io  0xf000-0xffff]
[    0.306843] pci_bus 0000:02: resource 1 [mem 0xfcd00000-0xfcefffff]
[    0.306845] pci_bus 0000:03: resource 0 [io  0xf000-0xffff]
[    0.306846] pci_bus 0000:03: resource 1 [mem 0xfcd00000-0xfcdfffff]
[    0.306848] pci_bus 0000:04: resource 0 [io  0xf000-0xffff]
[    0.306850] pci_bus 0000:04: resource 1 [mem 0xfcd00000-0xfcdfffff]
[    0.306851] pci_bus 0000:05: resource 0 [io  0xe000-0xefff]
[    0.306853] pci_bus 0000:05: resource 1 [mem 0xfcb00000-0xfccfffff]
[    0.306854] pci_bus 0000:05: resource 2 [mem 0xd0000000-0xe01fffff 64bit pref]
[    0.306868] pci_bus 0000:06: resource 0 [io  0xe000-0xefff]
[    0.306869] pci_bus 0000:06: resource 1 [mem 0xfcb00000-0xfcbfffff]
[    0.306871] pci_bus 0000:06: resource 2 [mem 0xd0000000-0xe01fffff 64bit pref]
[    0.306872] pci_bus 0000:07: resource 0 [io  0xe000-0xefff]
[    0.306874] pci_bus 0000:07: resource 1 [mem 0xfcb00000-0xfcbfffff]
[    0.306875] pci_bus 0000:07: resource 2 [mem 0xd0000000-0xe01fffff 64bit pref]
[    0.306878] pci_bus 0000:09: resource 1 [mem 0xfc800000-0xfcafffff]
[    0.307122] pci 0000:07:00.0: disabling ATS
[    0.307145] pci 0000:07:00.1: D0 power state depends on 0000:07:00.0
[    0.307332] PCI: CLS 64 bytes, default 64
[    0.307337] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.307338] software IO TLB: mapped [mem 0x00000000b2031000-0x00000000b6031000] (64MB)
[    0.307373] Trying to unpack rootfs image as initramfs...
[    0.307432] LVT offset 0 assigned for vector 0x400
[    0.309045] perf: AMD IBS detected (0x000003ff)
[    0.310447] Initialise system trusted keyrings
[    0.310455] Key type blacklist registered
[    0.310482] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[    0.310488] zbud: loaded
[    0.310638] integrity: Platform Keyring initialized
[    0.310640] integrity: Machine keyring initialized
[    0.317816] Key type asymmetric registered
[    0.317818] Asymmetric key parser 'x509' registered
[    0.317831] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[    0.317878] io scheduler mq-deadline registered
[    0.317879] io scheduler kyber registered
[    0.317887] io scheduler bfq registered
[    0.318974] pcieport 0000:00:01.1: PME: Signaling with IRQ 26
[    0.319037] pcieport 0000:00:01.1: AER: enabled with IRQ 26
[    0.319153] pcieport 0000:00:01.2: PME: Signaling with IRQ 27
[    0.319200] pcieport 0000:00:01.2: AER: enabled with IRQ 27
[    0.319311] pcieport 0000:00:03.1: PME: Signaling with IRQ 28
[    0.319358] pcieport 0000:00:03.1: AER: enabled with IRQ 28
[    0.319532] pcieport 0000:00:07.1: PME: Signaling with IRQ 30
[    0.319587] pcieport 0000:00:07.1: AER: enabled with IRQ 30
[    0.319688] pcieport 0000:00:08.1: PME: Signaling with IRQ 31
[    0.319749] pcieport 0000:00:08.1: AER: enabled with IRQ 31
[    0.320343] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    0.320504] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[    0.320525] ACPI: button: Power Button [PWRB]
[    0.320560] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[    0.321856] ACPI: button: Power Button [PWRF]
[    0.322864] Estimated ratio of average max frequency by base frequency (times 1024): 1110
[    0.322879] Monitor-Mwait will be used to enter C-1 state
[    0.322886] ACPI: \_SB_.PLTF.C000: Found 2 idle states
[    0.323019] ACPI: \_SB_.PLTF.C002: Found 2 idle states
[    0.323132] ACPI: \_SB_.PLTF.C004: Found 2 idle states
[    0.323225] ACPI: \_SB_.PLTF.C006: Found 2 idle states
[    0.323338] ACPI: \_SB_.PLTF.C008: Found 2 idle states
[    0.323458] ACPI: \_SB_.PLTF.C00A: Found 2 idle states
[    0.323550] ACPI: \_SB_.PLTF.C001: Found 2 idle states
[    0.323663] ACPI: \_SB_.PLTF.C003: Found 2 idle states
[    0.323779] ACPI: \_SB_.PLTF.C005: Found 2 idle states
[    0.323904] ACPI: \_SB_.PLTF.C007: Found 2 idle states
[    0.324021] ACPI: \_SB_.PLTF.C009: Found 2 idle states
[    0.324114] ACPI: \_SB_.PLTF.C00B: Found 2 idle states
[    0.324382] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    0.324567] 00:05: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[    0.327838] Non-volatile memory driver v1.3
[    0.327840] Linux agpgart interface v0.103
[    0.339883] tpm_crb MSFT0101:00: Disabling hwrng
[    0.340139] AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
[    0.340944] ahci 0000:02:00.1: version 3.0
[    0.341076] ahci 0000:02:00.1: SSS flag set, parallel bus scan disabled
[    0.341117] ahci 0000:02:00.1: AHCI 0001.0301 32 slots 6 ports 6 Gbps 0x33 impl SATA mode
[    0.341120] ahci 0000:02:00.1: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part sxs deso sadm sds apst
[    0.341583] scsi host0: ahci
[    0.341692] scsi host1: ahci
[    0.341788] scsi host2: ahci
[    0.341880] scsi host3: ahci
[    0.341978] scsi host4: ahci
[    0.342144] scsi host5: ahci
[    0.342182] ata1: SATA max UDMA/133 abar m131072@0xfce80000 port 0xfce80100 irq 38
[    0.342185] ata2: SATA max UDMA/133 abar m131072@0xfce80000 port 0xfce80180 irq 38
[    0.342186] ata3: DUMMY
[    0.342187] ata4: DUMMY
[    0.342189] ata5: SATA max UDMA/133 abar m131072@0xfce80000 port 0xfce80300 irq 38
[    0.342191] ata6: SATA max UDMA/133 abar m131072@0xfce80000 port 0xfce80380 irq 38
[    0.342236] ACPI: bus type drm_connector registered
[    0.342949] [drm] Initialized simpledrm 1.0.0 20200625 for simple-framebuffer.0 on minor 0
[    0.343784] fbcon: Deferring console take-over
[    0.343785] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
[    0.343918] usbcore: registered new interface driver usbserial_generic
[    0.343923] usbserial: USB Serial support registered for generic
[    0.343984] rtc_cmos 00:03: RTC can wake from S4
[    0.344201] rtc_cmos 00:03: registered as rtc0
[    0.344229] rtc_cmos 00:03: setting system clock to 2023-11-23T07:44:33 UTC (1700725473)
[    0.344256] rtc_cmos 00:03: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[    0.344299] amd_pstate: driver load is disabled, boot with specific mode to enable this
[    0.344388] ledtrig-cpu: registered to indicate activity on CPUs
[    0.344517] hid: raw HID events driver (C) Jiri Kosina
[    0.344647] drop_monitor: Initializing network drop monitor service
[    0.356958] Initializing XFRM netlink socket
[    0.356999] NET: Registered PF_INET6 protocol family
[    0.412994] Freeing initrd memory: 43164K
[    0.417658] Segment Routing with IPv6
[    0.417659] RPL Segment Routing with IPv6
[    0.417670] In-situ OAM (IOAM) with IPv6
[    0.417697] NET: Registered PF_PACKET protocol family
[    0.418626] microcode: CPU0: patch_level=0x08701030
[    0.418627] microcode: CPU1: patch_level=0x08701030
[    0.418629] microcode: CPU2: patch_level=0x08701030
[    0.418629] microcode: CPU3: patch_level=0x08701030
[    0.418632] microcode: CPU5: patch_level=0x08701030
[    0.418634] microcode: CPU6: patch_level=0x08701030
[    0.418635] microcode: CPU7: patch_level=0x08701030
[    0.418636] microcode: CPU8: patch_level=0x08701030
[    0.418637] microcode: CPU9: patch_level=0x08701030
[    0.418639] microcode: CPU10: patch_level=0x08701030
[    0.418640] microcode: CPU11: patch_level=0x08701030
[    0.418641] microcode: CPU4: patch_level=0x08701030
[    0.418657] microcode: Microcode Update Driver: v2.2.
[    0.418767] resctrl: L3 allocation detected
[    0.418769] resctrl: MB allocation detected
[    0.418769] resctrl: L3 monitoring detected
[    0.418773] IPI shorthand broadcast: enabled
[    0.421023] sched_clock: Marking stable (420570915, 257153)->(440078727, -19250659)
[    0.421129] registered taskstats version 1
[    0.421554] Loading compiled-in X.509 certificates
[    0.423596] Loaded X.509 cert 'Build time autogenerated kernel key: f271cd65eff4f5a5fef9c863a61d0e22b7a0cf20'
[    0.426640] zswap: loaded using pool zstd/zsmalloc
[    0.428985] Key type .fscrypt registered
[    0.428986] Key type fscrypt-provisioning registered
[    0.429988] PM:   Magic number: 15:185:724
[    0.434879] RAS: Correctable Errors collector initialized.
[    0.810321] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    0.810746] ata1.00: ATA-9: SanDisk SSD PLUS 120GB, UE5100RL, max UDMA/133
[    0.810748] ata1.00: 234455040 sectors, multi 1: LBA48 NCQ (depth 32)
[    0.811875] ata1.00: Features: Dev-Sleep
[    0.815292] ata1.00: configured for UDMA/133
[    0.815396] scsi 0:0:0:0: Direct-Access     ATA      SanDisk SSD PLUS 00RL PQ: 0 ANSI: 5
[    0.815655] sd 0:0:0:0: [sda] 234455040 512-byte logical blocks: (120 GB/112 GiB)
[    0.815663] sd 0:0:0:0: [sda] Write Protect is off
[    0.815665] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    0.815675] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    0.815690] sd 0:0:0:0: [sda] Preferred minimum I/O size 512 bytes
[    0.818518]  sda: sda1 sda2 sda3
[    0.818623] sd 0:0:0:0: [sda] Attached SCSI disk
[    1.131838] ata2: SATA link down (SStatus 0 SControl 300)
[    1.330875] tsc: Refined TSC clocksource calibration: 3593.247 MHz
[    1.330887] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x33cb683f3f7, max_idle_ns: 440795309157ns
[    1.330918] clocksource: Switched to clocksource tsc
[    1.602876] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    1.602969] ata5.00: ATA-11: HS-SSD-E100 512G, HT3418B2, max UDMA/133
[    1.612871] ata5.00: 1000215216 sectors, multi 1: LBA48 NCQ (depth 32), AA
[    1.638942] ata5.00: configured for UDMA/1
the out put is too big this is what I can show here
