I have a simple question
Hello, I want to make the switch from Win 11 over to Linux and I have chosen Garuda. I, a simple question. Will my PC run Garuda? I have a Ryzen 7 3700x, 16 GB ram, and a GTX 1660 Super. It’s the 1660 I have my worry’s about.
Try Garuda from the live usb and try :smile:
If everything works then there should be no reason why it will not when you install it
Thank you
Im running a r5 3600 with an rx580 and while its VERY RAM-hungry for a Linux, Garuda runs admirably. Luckily i run 32gigs of RAM, so im fine with that.
Especially the gaming performance is very, very good. They totally deliver on that promise.
btw…
Garuda uses a relatively large amount of RAM compared to other distributions. This is true. But you should get rid of old views from 10-20 years ago. Today’s operating systems are very good at managing RAM usage. Unused RAM is useless RAM.
