I have a problem with Screen share
Well in a nutshell, when I try to share my screen it will display that I’m sharing it but instead of sharing, it is just showing infinite loading, that never ends.
Kernel: 6.8.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=ebed6cff-30a0-4478-a55d-e7ed3e8c1b70 rw rootflags=subvol=@
quiet resume=UUID=3651864e-f610-4353-8d3c-d132bc390596 loglevel=3 ibt=off
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B360-G GAMING v: Rev 1.xx
serial: <superuser required> part-nu: ASUS_MB_CNL uuid: <superuser required>
UEFI: American Megatrends v: 1703 date: 09/02/2019
Info: model: Intel Core i5-9400F bits: 64 type: MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF6
desc: 1x9 MiB
Speed (MHz): avg: 1200 min/max: 800/4100 scaling: driver: intel_pstate
governor: powersave cores: 1: 1200 2: 1200 3: 1200 4: 1200 5: 1200 6: 1200
bogomips: 34798
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate]
vendor: Micro-Star MSI driver: nvidia v: 550.78
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
2024-04; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: none off: DP-2,HDMI-A-1 empty: DP-1,DP-3
bus-ID: 01:00.0 chip-ID: 10de:2504 class-ID: 0300
Device-2: Sonix Foscam Webcam W41 Audio driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3
chip-ID: 2c45:6366 class-ID: 0102 serial: <filter>
d-rect: 4480x2520 display-ID: 0
Monitor-1: DP-2 pos: primary,top-left res: 2560x1440 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: bottom-r res: 1920x1080 size: N/A modes: N/A
x11: drv: zink inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.78
API: Vulkan v: 1.3.279 layers: 14 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 550.78 device-ID: 10de:2504
17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.6-arch1.2 (LLVM 17.0.6)
Device-2: NVIDIA GA106 High Definition Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228e
Device-3: Sonix Foscam Webcam W41 Audio driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.8.9-zen1-1-zen status: kernel-api with: aoss
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
Local Storage: total: 2.05 TiB used: 596.48 GiB (28.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate
model: XPG GAMMIX S11 Pro size: 238.47 GiB block-size: physical: 512 B
fw-rev: 42A4SANA temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
ID-1: / raw-size: 51.6 GiB size: 51.6 GiB (100.00%) used: 24.05 GiB (46.6%)
fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
ID-2: /boot/efi raw-size: 512.6 MiB size: 511.6 MiB (99.80%)
used: 588 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6
ID-3: /home raw-size: 935.28 GiB size: 935.28 GiB (100.00%)
used: 572.43 GiB (61.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 51.6 GiB size: 51.6 GiB (100.00%)
used: 24.05 GiB (46.6%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
ID-5: /var/tmp raw-size: 51.6 GiB size: 51.6 GiB (100.00%)
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 6 dev: /dev/zram0
ID-2: swap-2 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
System Temperatures: cpu: 39.0 C mobo: N/A
Memory: total: 32 GiB available: 31.27 GiB used: 4.47 GiB (14.3%)
Processes: 336 Power: uptime: 5m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.46 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1993 libs: 556 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.34
System install date:     2024-03-30
Last full system update: 2024-05-04
Have you tried changing to x11 instead of wayland at the login screen
Please, post full log from garuda-inxi. Edit your post :slight_smile:
Thanks a lot, it helped
