sudo pacman -Syu
[sudo] password for partha:
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur is up to date
:: Replace crda with core/wireless-regdb? [Y/n] y
resolving dependencies...
:: poppler-git and poppler are in conflict. Remove poppler? [y/N] y
:: removing poppler breaks dependency 'poppler=22.03.0' required by poppler-qt5
Another solved thread said to remove all conflicting package but that keeps expanding as when i
sudo pacman -R cups-filters
checking dependencies...
:: removing cups-filters breaks dependency 'cups-filters' required by cups
:: removing cups-filters breaks dependency 'cups-filters>=1.0.42' required by foomatic-db-engine
:: removing cups-filters breaks dependency 'cups-filters' required by gutenprint
:: removing cups-filters breaks dependency 'cups-filters' required by printer-support
I tried removing all 4 poppler packages manually but i am not able to do so because they keep showing inter-dependencies.
sudo pacman -Syu
core is up to date
extra is up to date
chaotic-aur 1668.9 KiB 688 KiB/s 00:02 [----------------------------------------------------------------------------------------] 100%
:: poppler-git and poppler are in conflict. Remove poppler? [y/N] N
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
Also i tried
sudo pacman -Syu --ignore=poppler
core is up to date
extra is up to date
partha@partha in ~ as 🧙 took 11s
[🔴] × sudo pacman -S poppler-glib && sudo pacman -Syu
:: poppler-glib and poppler-glib-git are in conflict. Remove poppler-glib-git? [y/N] y
Packages (2) poppler-glib-git-22.03.0.r84.g8942ba12-1 [removal] poppler-glib-22.03.0-1
Total Download Size: 0.27 MiB
Total Installed Size: 2.78 MiB
Net Upgrade Size: 0.02 MiB
:: Retrieving packages...
poppler-glib-22.03.0-1-x86_64 277.6 KiB 125 KiB/s 00:02 [----------------------------------------------------------------------------------------] 100%
(1/1) checking keys in keyring [----------------------------------------------------------------------------------------] 100%
(1/1) checking package integrity [----------------------------------------------------------------------------------------] 100%
(1/1) loading package files [----------------------------------------------------------------------------------------] 100%
(1/1) checking for file conflicts [----------------------------------------------------------------------------------------] 100%
(2/2) checking available disk space [----------------------------------------------------------------------------------------] 100%
==> root: 291
(1/1) removing poppler-glib-git [----------------------------------------------------------------------------------------] 100%
(1/1) installing poppler-glib [----------------------------------------------------------------------------------------] 100%
(1/7) Arming ConditionNeedsUpdate...
(2/7) Refreshing PackageKit...
(3/7) Foreign/AUR package notification
ani-cli 1.9-1
crda 4.14-4
davfs2 1.6.1-1
lockdown-ms 20130326-4
lohit-fonts 2.95.5.1-2
snapd 2.55.2-1
(4/7) Orphaned package notification...
=> No orphans found.
(5/7) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/locale.gen.pacnew
/etc/pamac.conf.pacnew
/etc/paru.conf.pacnew
Please check and merge
(6/7) Performing snapper post snapshots for the following configurations...
==> root: 292
(7/7) Syncing all file systems...
core is up to date
extra is up to date
chaotic-aur 1668.9 KiB 954 KiB/s 00:02 [----------------------------------------------------------------------------------------] 100%
my system did not have poppler-git, i believe the updater was attempting to install it and i have no idea why.
i recently reinstalled my entire OS from the 210809.iso about a month ago.
i had this same poppler-git issue back then, but it rectified itself with the 'pacman -Syu' command as mentioned in a previous thread regarding this issue and just reappeared yesterday evening.
i normally use 'update' from terminal to keep my system updated.
the Garuda version i have is the Dragonized gaming edition.
