I Can't Understand The Packaging system
I am full-stack developer and i use laravel, and i am new to Garuda and i like the look and the style but, it seems i can’t find a source where i can download from php-mysql and php-http so i looked for other package manager than pacman or yay, and i found dnf. could not use it because of messing rpm packages :|. know i am stuck i need some hellp becuse i started to feel uncomfortable with this distribution even though i like it.
If there is any source to learn more about the distribution and the Packaging system please i need it.
garuda welcome 2
As you are a full stack developer you are aware the more information you provide, the easier it is for someone to help you?
:warning: Missing information requested in the template may result in not receiving assistance :warning:
Search the web and forums
Read How to search for solutions the right way | Garuda Linux wiki
Read FAQ and Tutorials Table of Contents
Issue still unresolved? Then:
ONE issue per topic.
Describe your issue in detail. The more we know, the better we can help
Show us the results of your searches, and what you’ve tried
After rebooting, post the FULL output of garuda-inxi in the body of the post (not linked externally, or collapsed with the “hide details” feature)
Format terminal output (including your garuda-inxi) as a code block by clicking the preformatted text button (</) , or put three tildes (~) above and below the text
What’s the problem with not posting garuda-inxi?
The data you posted are included in garuda-inxi, just copy and paste.
It contains additional, useful information about the status of your system.
Format terminal output (including your garuda-inxi) as a code block by clicking the preformatted text button (</>) , or put three tildes (~) above and below the text
Without garuda-inxi this request will be moved to 412 Precondition Failed
Try pacseek,
This is not a general Linux help forum.
You lack the basic understanding of different Linux distribution packaging, hence you haven’t yet grasped the different package managers or which package management processes or command structures exist. Garuda is based on the Arch Linux distribution.
I very strongly suggest a good start would be the Arch Linux Wiki. :smiley:
Welcome to Garuda Linux! :slight_smile:
https://wiki.archlinux.org/title/Pacman/Rosetta
