I am using dragonized garuda linux. The only way that i know that you can pin stuff in the dock is by opening them and then just right click and pin it. Well for Lightpad that can't happen. Lightpad is sort of menu that opens and shows all applications and goes above everything so in order to open the dock to pin it you must close the software.
Also if anyone knows any sort of software that opens up a menu and shows all applications and you can make folders and stuff just like the "Show applications" that Pop_OS has for garuda would be appreciated
