I can't get my external moniter to work
Hello everyone,
This is my first time every using linux, everything was going well and i just installed garuda dragonized, during installation my moniter was working fine with proprietary drivers, but after installation it just wouldn’t work
PS, i am using an acer nitro 5 laptop with an external moniter, screen works fine
Kernel: 6.6.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=b5c7108d-4efe-4d3a-a3c0-e1f0a940d572 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Laptop System: Acer product: Nitro AN515-53 v: V1.28
Mobo: CFL model: Freed_CFS v: V1.28 serial: <superuser required>
UEFI: Insyde v: 1.28 date: 08/05/2019
ID-1: BAT1 charge: 44.7 Wh (100.0%) condition: 44.7/48.9 Wh (91.4%)
volts: 17.0 min: 15.2 model: LG PABAS0241231 type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF4
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 888 high: 900 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 801 3: 900 4: 861
5: 896 6: 900 7: 900 8: 900 9: 900 10: 900 11: 900 12: 900 bogomips: 52799
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630]
vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-9.5
process: Intel 14nm built: 2016-20 ports: active: eDP-1 empty: none
bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 545.29.02
2023-10; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c8d class-ID: 0300
Device-3: Realtek HD WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:8 chip-ID: 0bda:5621
Monitor-1: eDP-1 res: 1536x864 size: N/A modes: N/A
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: nvidia
inactive: device-2
GT2) device-ID: 8086:3e9b memory: 15.1 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.269 layers: 14 device: 0 type: integrated-gpu
name: Intel UHD Graphics 630 (CFL GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:3e9b surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce GTX 1050 driver: nvidia
v: 545.29.02 device-ID: 10de:1c8d surfaces: xcb,xlib,wayland device: 2
type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
Device-1: Intel Cannon Lake PCH cAVS vendor: Acer Incorporated ALI
Device-2: NVIDIA GP107GL High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Device-3: HP HyperX SoloCast driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:3
chip-ID: 03f0:078b class-ID: 0300
Device-4: Kingston HyperX Cloud Alpha S
lanes: 1 mode: 1.1 bus-ID: 1-3:5 chip-ID: 0951:16ed class-ID: 0300
API: ALSA v: k6.6.2-zen1-1-zen status: kernel-api with: aoss
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 07:00.1 chip-ID: 10ec:8168
IF: enp7s0f1 state: down mac: <filter>
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:9
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 5.1
lmp-v: 10 status: discoverable: no pairing: no class-ID: 7c010c
Device-2: SINO WEALTH Bluetooth Keyboard driver: hid-generic,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:7
chip-ID: 258a:00e1 class-ID: 0300
Local Storage: total: 1.82 TiB used: 22.29 GiB (1.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S2000G
lanes: 4 tech: SSD serial: <filter> fw-rev: SBM02103 temp: 43.9 C
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 22.29 GiB (1.2%)
used: 22.29 GiB (1.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.46 GiB used: 1024 KiB (0.0%)
System Temperatures: cpu: 60.0 C pch: 69.0 C mobo: N/A
Processes: 324 Uptime: 11m wakeups: 0 Memory: total: 16 GiB
available: 15.46 GiB used: 4.9 GiB (31.7%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1979 libs: 570 tools: octopi,paru Shell: fish
v: 3.6.1 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
System install date:     2023-11-22
Last full system update: 2023-11-22
Either use x11 in the login screen instead of Wayland or use the following kernel boot parameter:
nvidia-drm.modeset=1
With
sudo cp /etc/default/grub /etc/default/grub.bak && sudo sed '/^GRUB_CMDLINE_LINUX_DEFAULT=/s/"$/ nvidia-drm.modeset=1 "/g' -i /etc/default/grub && sudo update-grub
i typed in the command prompt, should i reboot?
You typed the one liner, right?
So, yes, you should reboot and leave Wayland in the login screen.
If it doesn’t work, logoff and on again, this time selecting plasma (x11) at login.
Interesting, switching to X11 fixed it, thank you so much for your help, i really want to get into linux but i didn’t know where to start. thank you again and have a good day / night
#1 Rule - stay away from Wayland in KDE.
#2 Rule - see #1 Rule.
The Wayland protocol originated in Red Hat-owned Fedora with GNOME and is slowly bleeding into other desktop environments and other distributions. For right now, Wayland is supposed to work pretty well in GNOME (in non Arch-based distributions), but not so much KDE.
It’s easy to boot into Wayland by mistake. At first you think it’s fine, but then you start noticing little differences and things seem odd, like you’re kicking off on an acid trip. Then you start to believe KDE hates you so, no, it must be 'shrooms!
That what KDE in Wayland feels like. Not very pleasant. :frowning:
Also, I’d bet there may be a more current BIOS update available than 2019 for your machine. BIOS concern hardware and are frequently updated to do so. :slight_smile:
