Hello
root=UUID=b782d464-2e78-4bbb-9106-83d6711ae27c rw [email protected]
Desktop: KDE Plasma v: 5.26.1 tk: Qt v: 5.15.6 info: latte-dock
Type: Desktop Mobo: INTEL model: H61 serial: <superuser required>
BIOS: American Megatrends v: 4.6.5 date: 08/10/2018
Info: model: Intel Core i3-3240 bits: 64 type: MT MCP arch: Ivy Bridge
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2554 high: 3400 min/max: 1600/3400 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3400 2: 2323 3: 1597
4: 2899 bogomips: 27135
vulnerable
Device-1: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics
driver: i915 v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13
ports: active: VGA-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:0152 class-ID: 0300
s-diag: 414mm (16.31")
Monitor-1: VGA-1 model: Samsung S19C150 serial: <filter> built: 2013
res: 1366x768 hz: 60 dpi: 85 gamma: 1.2 size: 410x230mm (16.14x9.06")
diag: 470mm (18.5") ratio: 16:9 modes: max: 1366x768 min: 720x400
OpenGL: renderer: Mesa Intel HD Graphics 2500 (IVB GT1) v: 4.2 Mesa
22.2.1 direct render: Yes
driver: snd_hda_intel v: kernel bus-ID: 2-1.4.3:9 chip-ID: 1b3f:2008
Device-2: Generalplus USB Audio Device type: USB
Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0
Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB
driver: r8188eu bus-ID: 2-1.4.4.3:11 chip-ID: 0bda:8179 class-ID: 0000
IF: wlp0s29u1u4u4u3 state: up mac: <filter>
Local Storage: total: 2.18 TiB used: 15.88 GiB (0.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1CH162
speed: 3.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC44
scheme: MBR
model: WD2500AAKX-08ERMA0 size: 232.89 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1H19 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 type: USB model: TO Exter nal USB 3.0
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: <filter> rev: 0103 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Netac model: OnlyDisk
size: 116.21 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 8.01 scheme: GPT
ID-5: /dev/sde maj-min: 8:64 type: USB vendor: SanDisk model: Cruzer
Glide 3.0 size: 14.91 GiB block-size: physical: 512 B logical: 512 B
type: N/A serial: <filter> rev: 1.00 scheme: MBR
ID-6: /dev/sdf maj-min: 8:80 type: USB vendor: SanDisk
model: Cruzer Blade size: 7.45 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1.00 scheme: MBR
ID-1: / raw-size: 125.46 GiB size: 125.46 GiB (100.00%) used: 15.88 GiB
(12.7%) fs: btrfs dev: /dev/sdc3 maj-min: 8:35
ID-2: /home raw-size: 125.46 GiB size: 125.46 GiB (100.00%) used: 15.88
GiB (12.7%) fs: btrfs dev: /dev/sdc3 maj-min: 8:35
ID-3: /var/log raw-size: 125.46 GiB size: 125.46 GiB (100.00%) used: 15.88
ID-4: /var/tmp raw-size: 125.46 GiB size: 125.46 GiB (100.00%) used: 15.88
ID-1: swap-1 type: zram size: 11.21 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 31.0 C mobo: N/A
Processes: 202 Uptime: 12m wakeups: 0 Memory: 11.21 GiB used: 2.14 GiB
(19.1%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 0 tools: octopi,paru
Shell: fish v: 3.5.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.22
pacman: error while loading shared libraries: libcrypto.so.3: cannot open shared object file: No such file or directory
Garuda ():
System install date: 2023-01-07
Last full system update: 2023-01-08
Hi
So I tried installing yaourt via the command, sudo pacman -S --needed base-devel git wget yajl
And it broke pacman. So i now get this error, pacman: error while loading shared libraries: libcrypto.so.3: cannot open shared object file: No such file or directory
One of the solutions I found was to download openssl-3.0.7-4-x86_64.pkg from a repository and take the libcrypto.so.3 file from there and add it to /usr/lib64 and give it all permissions. Im not sure if that will work plus I am unable to copy or move files to /usr/lib64
This is the link for the above solution I tried : Pacman: error while loading shared libraries: libcrypto.so.3 - #5 by Aragorn - Support - Manjaro Linux Forum
Is this the only way to fix pacman? I am using Garuda Dragonised. Garuda Assistant fails and gives the same error as above, pacman: error while loading shared libraries: libcrypto.so.3: cannot open shared object file: No such file or directory
