Add new screenshot function to .config/hypr/hyprland.conf
# Screenshots:
bind =,Print,exec,grim && notify-send Screenshot captured
# https://github.com/hyprwm/contrib/blob/main/grimblast/grimblast.1.scd
# $mainMod+P: Current window
# $mainMod+Shift+p: Select area
# $mainMod+Alt+p Current output
# $mainMod+Ctrl+p All outputs
bind = $mainMod, p, exec, grimblast save active
bind = $mainMod SHIFT, p, exec, grimblast save area
bind = $mainMod ALT, p, exec, grimblast save output
bind = $mainMod CTRL, p, exec, grimblast save screen
sudo pacman -S grimblast-git
Coming soon
Monthly calendar when you click on the date in the waybar.
The illustrations shown here may differ slightly from the standard installation (colors, waybar, etc.).
New ISO comes only after bug fix.
I'm not a developer, just curious... why exactly is waybar-hyprland needed... I had read that waybar supports hyprland workspaces, and on another system I replaced waybar-hyprland with just waybar and all appears to work fine. waybar and spdlog 1.12 doesn't have any dependency issues...
@darkhorse raises an interesting pointâit may no longer be needed. Check out this comment on a related GitHub issue: Can't install waybar-hyprland on Arch · Issue #2177 · Alexays/Waybar · GitHub
First and foremost, this bug is closed because the problem has been fixed upstream, and you donât need to do anything. In fact, you probably shouldnât use the
waybar-hyprland
AUR package at all because AFIK mainline waybar now has all the hyprland support it used to patch in. Just install the waybar package and itâll do the thing.Just for your reference on AUR usage, my suggestion isnât to put on the command line, itâs to edit in the PKGBUILD. After you ran that yay command once (whether the build succeeded or failed), it would leave a directory
/home/$USER/.cache/yay/waybar-hyprland
containing all the sources and a file named PKGBUILD that describes to archâs build system how to make the package. If you open that file up in a text editor, you can make customizations to the build/install process, and my suggestion was to drop that sed command into the section/function marked build(). What that would do is edit one of the waybar source files before the build with sed (which is itself a text editor; it edits text by structured command instead of on screen) to insert some includes that used to be implicitly pulled in and arenât anymore.
Issue 10 sec. blackscreen
Fix
Nearly perfect
Check first post first for more information.
https://iso.builds.garudalinux.org/iso/community/hyprland/230830/
https://iso.builds.garudalinux.org/iso/community/hyprland/230831/
This update broke wlr/workspaces
, do not update or restore last snapshot.
garuda-hyprland-settings-0.3.25-1 geoip-database-20230901-1 hyprland-git-0.29.0.r21.f69c5469-1 spdlog-git-1.12.0.r13.g3aceda04-1 thunar-4.18.7-1
Releases 8/30 & 8/31 both boot through into a black home screen with a dead center mouse cursor. Sha's check just fine.
I'll have to retry an older release as thos booted just fine.
The issue might be because of this :
(The actual problem is with hyprland itself )
There is a small script in 8/31 which will fix this problem after installation is completed, by setting up the best possible display configuration in hyprland.conf
by itself.
Thanks @ankur. Right, it was just a live environment. Understood that the script with run after install.
https://iso.builds.garudalinux.org/iso/community/hyprland/230902/
Moving the mouse coursor up to the top can help, sometimes it need 30 sec.
If all fail, you can use TTY3 and log in garuda, garruda, hyprstart, enter.
Sorry for the inconvenience.
Add tooltip calendar.
Did a thing today, swapped out the ssd on my main desktop machine wich was home for win 11, which i never used and my MX Linux and put it in the drawer. Did a fresh install on a new 2 TB ssd with the 0902 iso with manual partitioning, all went smooth Garuda right now is roaming free on this machine, dual headed
Sure, its a Mac. Of course, there is also a light version. What I don
t really get get along with yet is the light version on xfce.
But nothing is final on this machine. I will do without the CD drive and install an SSD., maybe also increase the RAM. Then I Iwould have enough space for all Garuda-De`s.
I love to play with it
Unfortunately, the Mac is not coatet with Teflon, otherwise Icould bake fried eggs on it.
https://iso.builds.garudalinux.org/iso/community/hyprland/230904/
Fixed.
Lock screen got a nice dark wallpaper.
New font for waybar.
Tooltip calendar on clock, and extra calendar on click.
Tooltip on click, monitor backlight, as always to change the brightness just scroll the mouse wheel.
Rocket launcher icon change to hamburger menu.
Have fun
