inxi:
Kernel: 5.18.0-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=21c7fde8-1bef-4f82-abc8-364dad2d6848 rw [email protected]
resume=UUID=59131e58-a432-49f0-bae1-aebf3325230e loglevel=3
Desktop: Tabby info: latte-dock wm: kwin_x11 dm: SDDM
Type: Laptop System: HP product: OMEN by HP Laptop 15-dc1xxx v: N/A
Mobo: HP model: 8574 v: 21.17 serial: <filter> UEFI: AMI v: F.22
date: 05/03/2021
ID-1: BAT0 charge: 3.9 Wh (7.6%) condition: 51.3/51.3 Wh (100.0%)
volts: 15.0 min: 15.4 model: HP Primary type: Li-ion serial: N/A
status: N/A
Info: model: Intel Core i7-9750H socket: BGA1440 (U3E1) note: check
bits: 64 type: MT MCP arch: Coffee Lake family: 6 model-id: 0x9E (158)
stepping: 0xD (13) microcode: 0xF0
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4136 high: 4201 min/max: 800/4500 base/boost: 3960/8300
scaling: driver: intel_pstate governor: performance volts: 1.1 V
ext-clock: 100 MHz cores: 1: 4173 2: 4175 3: 4046 4: 4201 5: 4173 6: 4128
7: 4197 8: 4188 9: 4186 10: 4175 11: 3877 12: 4119 bogomips: 62399
Device-1: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 515.43.04 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-05) arch: Turing pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f11 class-ID: 0300
Device-2: Lite-On HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 04ca:707f class-ID: 0e02 serial: <filter>
compositors: 1: kwin_x11 2: Tabby driver: X: loaded: nvidia gpu: nvidia
Screen-1: 0 s-res: 1920x1080 s-dpi: 143 s-size: 341x191mm (13.43x7.52")
s-diag: 391mm (15.39")
Monitor-1: DP-2 res: 1920x1080 hz: 60 dpi: 142
OpenGL: renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2
v: 4.6.0 NVIDIA 515.43.04 direct render: Yes
Device-2: NVIDIA TU106 High Definition Audio vendor: Hewlett-Packard
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Sound Server-1: ALSA v: k5.18.0-zen1-1-zen running: yes
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 3c:00.0 chip-ID: 10ec:8168
speed: 5 GT/s lanes: 1 bus-ID: 3d:00.0 chip-ID: 8086:2723 class-ID: 0280
IF-ID-1: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
bus-ID: 1-7:4 chip-ID: 8087:0029 class-ID: e001
v: 3.0 port: 5020 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 1.84 TiB used: 69.55 GiB (3.7%)
model: MZVLB1T0HBLR-000H1 size: 953.87 GiB block-size: physical: 512 B
rev: HPS0NEXF temp: 54.9 C scheme: GPT
SMART: yes health: PASSED on: 247d 21h cycles: 824
read-units: 50,721,033 [25.9 TB] written-units: 53,054,602 [27.1 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
family: based SSDs size: 931.51 GiB block-size: physical: 512 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 1B6Q temp: 40 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 236d 22h cycles: 491
written: 2.16 TiB Pre-Fail: reallocated sector: 99 threshold: 10
ID-1: / raw-size: 896.9 GiB size: 896.9 GiB (100.00%)
used: 69.55 GiB (7.8%) fs: btrfs block-size: 4096 B dev: /dev/sda2
maj-min: 8:2
used: 563 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 896.9 GiB size: 896.9 GiB (100.00%)
maj-min: 8:2
ID-4: /var/log raw-size: 896.9 GiB size: 896.9 GiB (100.00%)
maj-min: 8:2
ID-5: /var/tmp raw-size: 896.9 GiB size: 896.9 GiB (100.00%)
maj-min: 8:2
ID-1: swap-1 type: zram size: 31.23 GiB used: 2 MiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.36 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 78.0 C pch: 80.0 C mobo: N/A gpu: nvidia
temp: 62 C
Processes: 388 Uptime: 1d 0m wakeups: 2 Memory: 31.23 GiB
used: 12.64 GiB (40.5%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 Packages: pacman: 1473 lib: 369 Shell: garuda-inxi (sudo)
default: Bash v: 5.1.16 running-in: tabby inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2021-07-24
Last full system update: 2022-05-29 ↻
Windows dual boot: Yes
Snapshots: Timeshift
Hi everyone!
I've noticed a problem with my HP Omen running Garuda Dragonized - the battery is not charging. Power adapter is fine - since when I switch to Windows, the battery will get charged without problems. I've noticed only today because I accidentally half-removed the charging jack and got an error that my battery is at 10%. When I plugged in the adapter, it drained to additional 7% and stayed at that.
The battery condition should be fine, laptop is two years old but I almost never use it unplugged.
Thanks in advance for any help in this matter.
