I want to make it so the Latvian keyboard (using as a English-Prussian layout) is the input method fcitx5 goes to when booting.
I’ve been having this problem for quite a while now. It’s always the second method that is the default and not the first, it seems.
There was this weird time where Turkmen was the default too even though it was the last keyboard there for some reason. Dunno what was up with that but I tried to delete them all to fix it but now it’s doing what I just described.
Right now, the second keyboard layout is Georgian, and it is being considered the default by fcitx5, as in, it’s the first one it boots to.
I switched it with Latvian and got Latvian to become the default method, seemingly proving my theory.
I suspect the “Input Method Off” and “Input Method On” parts of the menu have something to do with it.
How do I make it so that Latvian, my first keyboard, can be the default keyboard?
Kernel: 6.6.47-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=2e27aff0-7e96-4683-8ac0-9bf4806d5923 rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A info: frameworks v: 6.5.0
wm: kwin_x11 with: krunner vt: 2 dm: 1: LightDM v: 1.32.0 note: stopped
2: SDDM Distro: Garuda base: Arch Linux
Type: Laptop System: HP product: HP ZBook 17 G3 v: N/A
Mobo: HP model: 80D6 v: KBC Version 10.75 serial: <superuser required>
part-nu: 1MY26EC#ABA uuid: <superuser required> UEFI: HP v: N81 Ver. 01.45
date: 01/06/2020
ID-1: BAT0 charge: 57.2 Wh (84.6%) condition: 67.6/67.6 Wh (100.0%)
volts: 11.6 min: 11.4 model: Hewlett-Packard Primary type: Li-ion
Info: model: Intel Core i5-6440HQ bits: 64 type: MCP arch: Skylake-S
desc: 1x6 MiB
Speed (MHz): avg: 2813 high: 3390 min/max: 800/3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 2755 2: 2718 3: 3390
4: 2391 bogomips: 20810
Device-1: Intel HD Graphics 530 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:191b class-ID: 0300
Device-2: NVIDIA GM204GLM [Quadro M3000M] vendor: Hewlett-Packard
driver: N/A alternate: nouveau non-free: 545.xx+ status: current (as of
2024-06; EOL~2026-12-xx) arch: Maxwell code: GMxxx process: TSMC 28nm
built: 2014-2019 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:13fa class-ID: 0300
Device-3: Cheng Uei Precision Industry (Foxlink) HP HD Camera
driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-7:2 chip-ID: 05c8:0383 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
compositor: kwin_x11 driver: X: loaded: intel unloaded: modesetting
alternate: fbdev,vesa dri: i965 gpu: i915 display-ID: :0 screens: 1
Monitor-1: eDP-1 mapped: eDP1 model: ChiMei InnoLux 0x1738 built: 2015
res: 1920x1080 hz: 60 dpi: 128 gamma: 1.2 size: 380x210mm (14.96x8.27")
diag: 437mm (17.2") ratio: 16:9 modes: 1920x1080
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 530 (SKL GT2)
device-ID: 8086:191b memory: 7.57 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 10 device: 0 type: integrated-gpu
name: Intel HD Graphics 530 (SKL GT2) driver: mesa intel v: 24.1.6-arch1.1
device-ID: 8086:191b surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.6-arch1.1 (LLVM
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a170 class-ID: 0403
Device-2: NVIDIA GM204 High Definition Audio vendor: Hewlett-Packard
bus-ID: 01:00.1 chip-ID: 10de:0fbb class-ID: 0403
API: ALSA v: k6.6.47-1-lts status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b7 class-ID: 0200
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:24f3 class-ID: 0280
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-12:4 chip-ID: 8087:0a2b
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.2
Local Storage: total: 1.14 TiB used: 165.95 GiB (14.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SanDisk model: THNSN5256GPUK
NVMe TOSHIBA 256GB size: 238.47 GiB block-size: physical: 512 B
fw-rev: 5KDA4103 temp: 42.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
tech: HDD rpm: 7200 serial: <filter> fw-rev: A3T0 scheme: GPT
ID-1: / raw-size: 237.97 GiB size: 237.97 GiB (100.00%)
used: 39.81 GiB (16.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
used: 454.9 MiB (88.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 914.01 GiB size: 914.01 GiB (100.00%)
used: 125.69 GiB (13.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 237.97 GiB size: 237.97 GiB (100.00%)
ID-5: /var/tmp raw-size: 237.97 GiB size: 237.97 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.5 GiB used: 3.27 GiB (21.1%)
System Temperatures: cpu: 63.0 C pch: 55.5 C mobo: N/A
Memory: total: 16 GiB available: 15.51 GiB used: 9.51 GiB (61.4%)
Processes: 324 Power: uptime: 13h 59m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 1 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 6.19 GiB services: org_kde_powerdevil,
Packages: 2182 pm: pacman pkgs: 2155 libs: 602 tools: paru,yay pm: flatpak
pkgs: 27 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi
default: Bash v: 5.2.32 running-in: konsole inxi: 3.3.35
System install date: 2024-06-13
Last full system update: 2024-08-27 ↻ ← Dont comment about this please, I've been having this problem before too so irrelevant :D
