When I install any new kernel, the NVidia GPU doesn't work: module nvidia is not available for current kernel. Is the corresponding package installed?
Typing optimus-manager
in the console gives this
How do you get the GPU working with other kernels?
[7] INFO: # Xorg pre-start hook
[7] INFO: Previous state was: {'type': 'pending_pre_xorg_start', 'requested_mode': 'nvidia', 'current_mode': N
one}
[7] INFO: Requested mode is: nvidia
[34] INFO: Available modules: ['nouveau']
[34] INFO: Unloading modules ['nouveau'] (if loaded)
[37] INFO: switching=none, nothing to do
[49] INFO: Setting Nvidia PCI power state to on
[62] INFO: Writing "on" to /sys/bus/pci/devices/0000:01:00.2/power/control
[255] INFO: Writing "on" to /sys/bus/pci/devices/0000:01:00.0/power/control
[255] INFO: Writing "on" to /sys/bus/pci/devices/0000:01:00.3/power/control
[255] INFO: Writing "on" to /sys/bus/pci/devices/0000:01:00.1/power/control
[315] INFO: Loading module nvidia
[315] ERROR: Xorg pre-start setup error
File "/usr/lib/python3.10/site-packages/optimus_manager/hooks/pre_xorg_start.py", line 51, in main
setup_kernel_state(config, prev_state, requested_mode)
File "/usr/lib/python3.10/site-packages/optimus_manager/kernel.py", line 22, in setup_kernel_state
_nvidia_up(config, hybrid=(requested_mode == "hybrid"))
File "/usr/lib/python3.10/site-packages/optimus_manager/kernel.py", line 95, in _nvidia_up
_load_nvidia_modules(config, available_modules)
File "/usr/lib/python3.10/site-packages/optimus_manager/kernel.py", line 164, in _load_nvidia_modules
_load_module(available_modules, "nvidia", options=nvidia_options)
File "/usr/lib/python3.10/site-packages/optimus_manager/kernel.py", line 241, in _load_module
raise KernelSetupError(
optimus_manager.kernel.KernelSetupError: module nvidia is not available for current kernel. Is the corresponding package installed ?
[315] INFO: Removing /etc/X11/xorg.conf.d/10-optimus-manager.conf (if present)
[315] INFO: Writing state {'type': 'pre_xorg_start_failed', 'switch_id': '20220930T204057', 'requested_mode':
'nvidia'}
My inxi
Kernel: 5.15.71-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=58203bda-e2e2-4c32-a006-c91d933cad4e rw rootflags=subvol=@
loglevel=3 quiet intel_iommu=on iommu=pt ibt=off
Type: Laptop System: Acer product: Predator PH315-53 v: V1.01
Mobo: CML model: QX50_CMS v: V1.01 serial: <superuser required>
UEFI: Insyde v: 1.01 date: 04/27/2020
ID-1: BAT1 charge: 44.0 Wh (99.8%) condition: 44.1/58.8 Wh (75.1%)
volts: 16.4 min: 15.4 model: SMP AP18E7M type: Li-ion serial: <filter>
status: N/A
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 level: v3 built: 2020 process: Intel 14nm family: 6
model-id: 0xA5 (165) stepping: 2 microcode: 0xF0
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3183 high: 3586 min/max: 800/5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 3586 2: 2961 3: 3444
4: 3498 5: 3499 6: 3500 7: 3500 8: 2754 9: 1948 10: 3388 11: 2753
12: 3373 bogomips: 62399
prctl and seccomp
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Acer Incorporated
ALI driver: i915 v: kernel arch: Gen-9.5 process: Intel 14nm
built: 2016-20 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Acer
Incorporated ALI driver: N/A alternate: nouveau non-free: 515.xx+
status: current (as of 2022-08) arch: Turing code: TUxxx
process: TSMC 12nm built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1f15 class-ID: 0300
Device-3: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 1-5:3
chip-ID: 0408:a061 class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: intel unloaded: modesetting
alternate: fbdev,vesa gpu: i915 display-ID: :0 screens: 1
Monitor-1: eDP-1 mapped: eDP1 model: AU Optronics 0x82ed built: 2018
res: 1920x1080 hz: 144 dpi: 143 gamma: 1.2 size: 340x190mm (13.39x7.48")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus-ID: 1-1.3:6
alternate: snd_soc_skl,snd_sof_pci_intel_cnl chip-ID: 08bb:29b0
bus-ID: 00:1f.3 class-ID: 0300 chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: Acer Incorporated
ALI driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: Texas Instruments PCM2900B Audio CODEC type: USB
Sound Server-1: ALSA v: k5.15.71-1-lts running: yes
Sound Server-4: PipeWire v: 0.3.58 running: yes
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
Device-2: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 07:00.0
chip-ID: 10ec:2600 class-ID: 0200
IF-ID-2: virbr1 state: down mac: <filter>
bus-ID: 1-14:5 chip-ID: 8087:0026 class-ID: e001
address: <filter>
Local Storage: total: 5.26 TiB used: 1.2 TiB (22.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBQNTY-512G-1014 size: 476.94 GiB block-size: physical: 512 B
rev: 11101100 temp: 24.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: A3J0
ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT275MX300SSD4
size: 256.17 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: R060 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Western Digital model: WD
Elements 2620 size: 3.64 TiB block-size: physical: 4096 B logical: 512 B
type: N/A serial: <filter> rev: 1023 scheme: GPT
ID-1: / raw-size: 468.84 GiB size: 468.84 GiB (100.00%) used: 362.32 GiB
(77.3%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:3
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 51.2 MiB
(53.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 468.84 GiB size: 468.84 GiB (100.00%) used: 362.32
GiB (77.3%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:3
ID-4: /var/log raw-size: 468.84 GiB size: 468.84 GiB (100.00%) used: 362.32
ID-5: /var/tmp raw-size: 468.84 GiB size: 468.84 GiB (100.00%) used: 362.32
ID-1: swap-1 type: zram size: 15.46 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 67.0 C pch: 81.0 C mobo: N/A
Processes: 344 Uptime: 7m wakeups: 1 Memory: 15.46 GiB used: 3.11 GiB
(20.1%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 alt: 11 clang: 14.0.6 Packages: pm: pacman
pkgs: 1971 libs: 517 tools: octopi,pamac,paru Shell: fish v: 3.5.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.21
Garuda (2.6.8-1):
System install date: 2021-11-24
Last full system update: 2022-09-30
Failed units: systemd-networkd-wait-online.service systemd-sysctl.service
