How to stop wallpaper switching
inxi -Faz
System:    Kernel: 5.14.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=7b5ef04c-915a-44d8-8328-1b5d9f8eccab
rw [email protected] quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine:   Type: Desktop Mobo: ASRock model: B450M Pro4 serial: <filter> UEFI: American Megatrends
v: P3.90 date: 12/09/2019
CPU:       Info: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ family: 17 (23)
model-id: 8 stepping: 2 microcode: 800820D cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 81435
Speed: 2895 MHz min/max: 1550/3400 MHz boost: enabled Core speeds (MHz): 1: 2895 2: 2928
3: 2880 4: 2244 5: 2405 6: 2324 7: 2991 8: 2239 9: 3047 10: 2933 11: 3257 12: 2401
Graphics:  Device-1: NVIDIA GM107 [GeForce GTX 750 Ti] vendor: ASUSTeK driver: nvidia v: 470.74
alternate: nouveau,nvidia_drm bus-ID: 06:00.0 chip-ID: 10de:1380 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: nvidia
unloaded: modesetting alternate: fbdev,nouveau,nv,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 3280x1170 s-dpi: 84 s-size: 993x354mm (39.1x13.9") s-diag: 1054mm (41.5")
Monitor-1: VGA-0 res: 1360x768 hz: 60 dpi: 84 size: 410x230mm (16.1x9.1") diag: 470mm (18.5")
Monitor-2: HDMI-0 res: 1920x1080 hz: 60 dpi: 82 size: 598x336mm (23.5x13.2") diag: 686mm (27")
OpenGL: renderer: NVIDIA GeForce GTX 750 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 470.74 direct render: Yes
Audio:     Device-1: NVIDIA GM107 High Definition Audio [GeForce 940MX] vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 06:00.1 chip-ID: 10de:0fbc class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel v: kernel
bus-ID: 08:00.3 chip-ID: 1022:1457 class-ID: 0403
Sound Server-1: ALSA v: k5.14.8-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASRock driver: r8169
v: kernel port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: D-Link DWA-140 RangeBooster N Adapter(rev.B3) [Ralink RT5372] type: USB
driver: rt2800usb bus-ID: 3-1:2 chip-ID: 2001:3c15 class-ID: 0000 serial: <filter>
IF: wlp7s0f3u1 state: down mac: <filter>
IF-ID-1: enp1s0f0u5 state: unknown speed: -1 duplex: half mac: <filter>
Bluetooth: Device-1: Huawei HRY-LX1T type: USB driver: rndis_host v: kernel bus-ID: 1-5:38
chip-ID: 12d1:108a class-ID: 0a00 serial: <filter>
Report: bt-service: enabled,stopped note: tool can't run
Drives:    Local Storage: total: 3 TiB used: 25.52 GiB (0.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102 size: 1.82 TiB
serial: <filter> rev: 0001 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Patriot model: Burst size: 223.57 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: KB.3 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Toshiba model: MQ04UBF100 size: 931.51 GiB
block-size: physical: 512 B logical: 512 B type: HDD rpm: 5400 serial: <filter> scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Generic model: Flash Disk size: 58.63 GiB
block-size: physical: 512 B logical: 512 B type: SSD serial: <filter> rev: 8.07 scheme: MBR
Partition: ID-1: / raw-size: 125.17 GiB size: 125.17 GiB (100.00%) used: 25.49 GiB (20.4%) fs: btrfs
dev: /dev/sdb4 maj-min: 8:20
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%) used: 26.1 MiB (5.1%) fs: vfat
dev: /dev/sdb3 maj-min: 8:19
ID-3: /home raw-size: 125.17 GiB size: 125.17 GiB (100.00%) used: 25.49 GiB (20.4%) fs: btrfs
ID-4: /var/log raw-size: 125.17 GiB size: 125.17 GiB (100.00%) used: 25.49 GiB (20.4%)
fs: btrfs dev: /dev/sdb4 maj-min: 8:20
ID-5: /var/tmp raw-size: 125.17 GiB size: 125.17 GiB (100.00%) used: 25.49 GiB (20.4%)
ID-1: swap-1 type: zram size: 15.55 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
ID-2: swap-2 type: partition size: 4.67 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sdb5
maj-min: 8:21
Sensors:   System Temperatures: cpu: 37.1 C mobo: N/A gpu: nvidia temp: 35 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
Info:      Processes: 360 Uptime: 59m wakeups: 0 Memory: 15.55 GiB used: 3.5 GiB (22.5%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1370 apt: 1 pacman: 1369
lib: 345 Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
I am new to Garuda Linux, i just installed it.
I have the problem that my wallpapers are switching like in a Slideshow and i dont know how to disable it.
By now i went 5 Times trough all the settings in "System Settings" and found nothing.
When i go to "Customize Desktop and wallpaper" and select a wallpaper and apply, the wallpaper appears but gets switched after 2 - 5min.
(And yes the Slideshow checkmark is deselected!)
The settings i configure there dosent seem to make any diffrence, it gets switched anyway.
i even moved all wallpapers out of the wallpaper folder (/usr/share/wallpapers) and it is still putting crappy wallpapers in my face.
My thougth on this is that maybe another App is switching The Wallpapers
Variety is a common one, check if you have that installed by accident
Bro i could kiss you. Thanks a lot!
