How to stop middle click from creaating sricky notes
how can i stop middle click from creating sticky notes in desktop
Hello.
 inxi -Faz
You do not post what you try, check the manual, please.
In KDE you can have knotes or other similar widgets.
If it is a widget and you don't need it, remove it.
Try also to right click on a note to see if you can configure.
Try remapping the middle click action.
Try...
