Hi everyone
Has anyone done this? I just haven't found any articles on the topic of replacing kwin with kwinft yet.
I think it won't hurt and maybe solve the my problems with the kwin crash
Kernel: 5.15.10-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=94fcb400-f6b5-43fc-a6a4-779aff3fdb59 rw [email protected]
resume=UUID=b7ee18a6-137d-4f7f-960f-8be0ab1d3c04 loglevel=3
IinAndEd:
Probably, otherwise the package would be pretty pointless.
It's supposed to be a drop-in replacement, so there won't be any articles. Build the package, install it, it will remove kwin
, done.
There were just small suspicions that the graphics of the system might not start anymore With direct replacement
It might not, but it's easy enough to reinstall the original package.
c00ter
22 December 2021 17:36
#5
Dive in. Learning can be adventurous.
I installed it, and after restarting there were constant flickers, so I had to roll back. From the noticeable, animations are faster and smoother and look nicer. So i are waiting for KDE Dragonized with wayland)
tbg
22 December 2021 18:26
#7
You have not provided a full inxi -Faz
output. If you had, I wouldn't need to ask the next questions.
Do you have an Nvidia graphics card?
If so, have you implemented the Nvidia troubleshooting recommendations from the Arch Wiki.
Again people, please provide a full inxi -Faz
output unless requested to provide an alternate (less detailed) version by forum assistants.
system
closed
5 January 2022 18:27
#8
