I installed Polybar to Gaming version but it's not appearing on the screen.
What should I do?
have you tried clicking on the desktop and typing polybar
yes, I did
I'm not sure I understand this.
Copy the configuration example from /usr/share/doc/polybar/config to $XDG_CONFIG_HOME/polybar/config
How to do it?
sudo cp /usr/share/doc/polybar/config $XDG_CONFIG_HOME/polybar/config
cp: missing destination file operand after '/usr/share/doc/polybar'
Oops, fixed it.
cp: missing destination file operand after '/usr/share/doc/polybar/config'
Do you mean you want to add polybar in KDE?
…boys wanna play…
cp "/usr/share/doc/polybar/config" "$XDG_CONFIG_HOME/polybar/config"
Don’t use sudo
. Don’t ask me “why?”. Read Archwiki about it.
And before you ask “why it still doesn’t work?”, I sincerely have no idea what polybar is and how it works.
