Hello Garuda Team,
I personally love what you guys have done with Garuda, 2 year linux user here and I have to say getting into arch hasn't been easier.
I've tried looking around for quite a bit, There's this Post Installation Wizard GUI thing that popped up right after installing, and I thought it was a cute tool that showed me all the suggestions and I could immediately recognize all the must have's that I did have from my main machine(Linux Mint). However, I chose to close it for the time being thinking I'll come think about it, since I'm on Storage Constraints.
Once I closed it I wasn't able to conjure that exact window. Garuda Assistant is great, but it simply isn't the same.
TLDR; can't find Post Installation Wizard that you get right after a fresh install, would be cool if I could know what command evokes it / if its possible to make it a separate application in Garuda's Repo?
Kernel: 5.19.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=df2ee2ee-7af4-4d63-8c10-45e2b8cfc621 rw rootflags=subvol=@
Type: Laptop System: HP product: HP ProBook 450 G5 v: N/A
Mobo: HP model: 837D v: KBC Version 02.2D.00 serial: <superuser required>
UEFI: HP v: Q85 Ver. 01.03.00 date: 07/20/2018
ID-1: BAT0 charge: 32.4 Wh (100.0%) condition: 32.4/32.4 Wh (100.0%)
volts: 12.9 min: 11.4 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 built: 2017 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 0xA (10) microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1700 high: 2000 min/max: 400/4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 2000 2: 800 3: 2000
4: 2000 5: 2000 6: 800 7: 2000 8: 2000 bogomips: 31999
vulnerable
PBRSB-eIBRS: Not affected
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
active: HDMI-A-1,eDP-1 empty: DP-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:5917 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce 930MX] vendor: Hewlett-Packard
driver: nvidia v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-07) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:134e
class-ID: 0302
Device-3: Chicony HP HD Camera type: USB driver: uvcvideo bus-ID: 1-6:5
chip-ID: 04f2:b5ee class-ID: 0e02
unloaded: nouveau alternate: fbdev,intel,nv,vesa gpu: i915 display-ID: :0
Screen-1: 0 s-res: 2732x768 s-dpi: 96 s-size: 722x203mm (28.43x7.99")
s-diag: 750mm (29.53")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: right model: LG (GoldStar) HD
built: 2014 res: 1366x768 hz: 60 dpi: 85 gamma: 1.2
size: 410x230mm (16.14x9.06") diag: 470mm (18.5") ratio: 16:9 modes:
max: 1366x768 min: 720x400
Monitor-2: eDP-1 pos: primary,left model: BOE Display 0x095e built: 2015
res: 1366x768 hz: 60 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa
22.1.6 direct render: Yes
Sound Server-1: ALSA v: k5.19.1-zen1-1-zen running: yes
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:24fd
bus-ID: 1-7:6 chip-ID: 8087:0a2b class-ID: e001
Local Storage: total: 252.8 GiB used: 9.86 GiB (3.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: PC401 HFS256GD9TNG-62A0A size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 80000E00 temp: 34.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: Cruzer Blade
size: 14.32 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: GPT
ID-1: / raw-size: 14.02 GiB size: 14.02 GiB (100.00%) used: 9.86 GiB
(70.3%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 14.02 GiB size: 14.02 GiB (100.00%) used: 9.86 GiB
ID-4: /var/log raw-size: 14.02 GiB size: 14.02 GiB (100.00%) used: 9.86
GiB (70.3%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-5: /var/tmp raw-size: 14.02 GiB size: 14.02 GiB (100.00%) used: 9.86
ID-1: swap-1 type: zram size: 7.66 GiB used: 1.5 MiB (0.0%) priority: 100
System Temperatures: cpu: 55.0 C pch: 50.0 C mobo: N/A
Processes: 268 Uptime: 36m wakeups: 1 Memory: 7.66 GiB used: 4.09 GiB
(53.5%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.1 Packages: pacman: 1207 lib: 306 Shell: fish v: 3.5.1
Garuda (2.6.6-1):
System install date: 2022-08-15
Last full system update: 2022-08-15 ↻
