Hello. I use pdanet on android to get unlimited hotspot (very few carriers in the United States offer unlimited hotspot). Pdanet accomplishes this by setting a proxy. To connect, I connect to the Pdanet hotspot and set my proxy a few different ways, but usually I add these lines to the end of ~/.config/fish/config.fish
export http_proxy="http://user:\\@192.168.49.1:8000/"
export ftp_proxy="ftp://user:\\@192.168.49.1:8000/"
export rsync_proxy="rsync://user:\\@192.168.49.1:8000/"
export no_proxy="localhost,127.0.0.1,192.168.1.1,::1,*.local"
export HTTP_PROXY="http://user:\\@192.168.49.1:8000/"
export FTP_PROXY="ftp://user:\\@192.168.49.1:8000/"
export RSYNC_PROXY="rsync://user:\\@192.168.49.1:8000/"
export NO_PROXY="localhost,127.0.0.1,192.168.1.1,::1,*.local"
export https_proxy="http://user:\\@192.168.49.1:8000/"
export HTTPS_PROXY="http://user:\\@192.168.49.1:8000/"
and then restart fish with,
source ~/.config/fish/config.fish
It can also be set with export commands like this:
export http_proxy=192.168.49.1:8000
export https_proxy=192.168.49.1:8000
and so on.
I've been doing this for many months and it's been working great, but recently I've been running into problems removing the proxy when I need to. It gets removed for some things, but I'm unable to use pamac-aur because it's still trying to run through the proxy. Tonight, it's apparently the same for yay and makepkg as well or, I should say for git because git is unable to clone from the AUR.
╭─[email protected] in ~/.work took 3s
╰─λ pamac install cuda-7.5
Warning: cuda-7.5 is only available from AUR
Preparing...
Checking cuda-7.5 dependencies...
Checking gcc5 dependencies...
Resolving dependencies...
Checking inter-conflicts...
To build (2):
gcc5 5.5.0-3 AUR
cuda-7.5 7.5.18-5 AUR
Edit build files : [e]
Apply transaction ? [e/y/N] y
Cloning gcc5 build files...
fatal: unable to access 'https://aur.archlinux.org/gcc5.git/': Failed to connect to 192.168.49.1 port 8000 after 128822 ms: Connection timed out
Error: Failed to build gcc5
╭─[email protected] in ~/.work took 2m16s
[🔴] × cd ~/build
╭─[email protected] in ~/build took 1ms
╰─λ git clone https://aur.archlinux.org/cuda-7.5
Cloning into 'cuda-7.5'...
fatal: unable to access 'https://aur.archlinux.org/cuda-7.5/': Failed to connect to 192.168.49.1 port 8000 after 128422 ms: Connection timed out
╭─[email protected] in ~/build took 2m8s
[🔴] × yay -S cuda-7.5
:: Checking for conflicts...
:: Checking for inner conflicts...
[Aur:2] gcc5-5.5.0-3 cuda-7.5-7.5.18-5
:: (0/2) Downloaded PKGBUILD: gcc5
:: (0/2) Downloaded PKGBUILD: cuda-7.5
-> error fetching gcc5: Cloning into 'gcc5'...
fatal: unable to access 'https://aur.archlinux.org/gcc5.git/': Failed to connect to 192.168.49.1 port 8000 after 129286 ms: Connection timed out
context: exit status 128
error fetching cuda-7.5: Cloning into 'cuda-7.5'...
fatal: unable to access 'https://aur.archlinux.org/cuda-7.5.git/': Failed to connect to 192.168.49.1 port 8000 after 129286 ms: Connection timed out
╭─[email protected] in ~/build took 2m15s
[🔴] × speedtest
Retrieving speedtest.net configuration...
Testing from T-Mobile USA (172.58.176.163)...
Retrieving speedtest.net server list...
Selecting best server based on ping...
Hosted by DediPath (Dallas, TX) [0.76 km]: 49.911 ms
Testing download speed................................................................................
Download: 2.96 Mbit/s
Testing upload speed......................................................................................................
Upload: 19.54 Mbit/s
╭─[email protected] in ~/build took 24s
╰─λ echo $http_proxy
╰─λ
The way I am attempting to disable the proxy is the same as I've always done it, by removing the export lines from config.fish and the restarting it. I have lately just been commenting out the lines like this:
#export http_proxy="http://user:\\@192.168.49.1:8000/"
#export ftp_proxy="ftp://user:\\@192.168.49.1:8000/"
#export rsync_proxy="rsync://user:\\@192.168.49.1:8000/"
#export no_proxy="localhost,127.0.0.1,192.168.1.1,::1,*.local"
#export HTTP_PROXY="http://user:\\@192.168.49.1:8000/"
#export FTP_PROXY="ftp://user:\\@192.168.49.1:8000/"
#export RSYNC_PROXY="rsync://user:\\@192.168.49.1:8000/"
#export NO_PROXY="localhost,127.0.0.1,192.168.1.1,::1,*.local"
#export https_proxy="http://user:\\@192.168.49.1:8000/"
#export HTTPS_PROXY="http://user:\\@192.168.49.1:8000/"
Now to set the proxy address is always instant, but to remove the proxy I must log out and back in for the proxy to actually be removed. Tonight I've even tried rebooting and all my pkg manager helpers are still trying to use the proxy.....
Can anyone please tell me why?
Here is my inxi:
╭─[email protected] in ~/.work took 9m16s
[🔴] × garuda-inxi
Kernel: 5.16.14-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=dfacdddb-42b3-448d-ba1f-7b7b8c8f1f0c rw [email protected]
Type: Laptop System: LENOVO product: 427639U v: ThinkPad W520
Mobo: LENOVO model: 427639U serial: <superuser required> UEFI: LENOVO
v: 8BET62WW (1.42 ) date: 07/26/2013
ID-1: BAT0 charge: 36.0 Wh (100.0%) condition: 36.0/93.2 Wh (38.7%)
volts: 12.8 min: 11.1 model: SANYO 42T4799 type: Li-ion serial: <filter>
status: Full
Info: model: Intel Core i7-2820QM bits: 64 type: MT MCP arch: Sandy Bridge
family: 6 model-id: 0x2A (42) stepping: 7 microcode: 0x2F
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1027 high: 1531 min/max: 800/3400 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 957 2: 1472 3: 797
4: 797 5: 1531 6: 971 7: 900 8: 798 bogomips: 36680
Type: l1tf
vendor: Lenovo driver: i915 v: kernel ports: active: LVDS-1 empty: VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0126 class-ID: 0300
Device-2: NVIDIA GF108GLM [Quadro 1000M] vendor: Lenovo driver: nvidia
v: 390.147 alternate: nouveau,nvidia_drm pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 link-max: lanes: 16 ports: active: none
empty: DP-1, DP-2, DP-3, LVDS-2, VGA-2 bus-ID: 01:00.0 chip-ID: 10de:0dfa
Device-3: Chicony Lenovo Integrated Camera (0.3MP) type: USB
driver: uvcvideo bus-ID: 1-1.6:5 chip-ID: 04f2:b217 class-ID: 0e02
loaded: modesetting failed: nvidia gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: LVDS-1 model: Lenovo built: 2009 res: 1920x1080 hz: 60
dpi: 142 gamma: 1.2 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: N/A v: N/A direct render: N/A
vendor: Lenovo ThinkPad T520 driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:1c20 class-ID: 0403
Device-2: NVIDIA GF108 High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0bea class-ID: 0403
Sound Server-1: ALSA v: k5.16.14-zen1-1-zen running: yes
Device-1: Intel 82579LM Gigabit Network vendor: Lenovo ThinkPad T520
driver: e1000e v: kernel port: 6080 bus-ID: 00:19.0 chip-ID: 8086:1502
Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
chip-ID: 8086:0085 class-ID: 0280
IF-ID-1: enp0s26u1u2 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Motorola PCS moto g power (2022) type: USB driver: rndis_host
v: kernel bus-ID: 1-1.2:7 chip-ID: 22b8:2e25 class-ID: 0a00
Device-2: Broadcom BCM2045B (BDC-2.1) type: USB driver: btusb v: 0.8
bus-ID: 1-1.4:4 chip-ID: 0a5c:217f class-ID: fe01 serial: <filter>
Report: ID: hci0 rfk-id: 2 state: up address: <filter>
Local Storage: total: 582.24 GiB used: 254.22 GiB (43.7%)
ID-1: /dev/mmcblk0 maj-min: 179:0 model: SD size: 116.48 GiB block-size:
physical: 512 B logical: 512 B type: SSD serial: <filter> scheme: GPT
model: WD5000LPCX-75VHAT1 size: 465.76 GiB block-size: physical: 4096 B
rev: 1A05 scheme: GPT
ID-1: / raw-size: 64 GiB size: 64 GiB (100.00%) used: 8.53 GiB (13.3%)
ID-2: /boot/efi raw-size: 100 MiB size: 98.4 MiB (98.42%)
used: 562 KiB (0.6%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 401.66 GiB size: 401.66 GiB (100.00%)
used: 245.68 GiB (61.2%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-4: /var/log raw-size: 64 GiB size: 64 GiB (100.00%)
used: 8.53 GiB (13.3%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-5: /var/tmp raw-size: 64 GiB size: 64 GiB (100.00%)
ID-1: swap-1 type: zram size: 23.36 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 43.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2509
Processes: 284 Uptime: 44m wakeups: 1 Memory: 23.36 GiB
used: 3.12 GiB (13.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1242 lib: 306 Shell: fish
v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.13
Garuda (2.5.6-2):
System install date: 2022-03-16
Last full system update: 2022-03-16
Is partially upgraded: Yes
Thanks so much for any help or insight....
