I noticed how to always download, instead of trying to open .zip files but I cannot get .jar files to always download. Instead, I am asked if I'm sure i want to launch the .jar. How can I change it so the default is to always download the .jar?
I added screenshots to help explain what I am seeing.
I unchecked "Always open".
Here is the prompt to launch .jar which I want to avoid.
Where is the "Always open" check box?
Kernel: 5.16.14-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=49e35eec-1ebd-48a5-bd14-4f07adbbc0b6 rw [email protected]
vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: G74Sx v: 1.0
Mobo: ASUSTeK model: G74Sx v: 1.0 serial: <superuser required>
BIOS: American Megatrends v: G74Sx.201 date: 04/27/2011
ID-1: BAT0 charge: 0 Wh (0.0%) condition: 64.3/78.0 Wh (82.5%) volts: 5.7
min: 14.8 model: ASUSTek type: Li-ion serial: N/A status: N/A
Info: model: Intel Core i7-2630QM bits: 64 type: MT MCP arch: Sandy Bridge
family: 6 model-id: 0x2A (42) stepping: 7 microcode: 0x2F
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 988 high: 1549 min/max: 800/2900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 893 2: 799 3: 908
4: 798 5: 925 6: 833 7: 1549 8: 1199 bogomips: 31929
Type: l1tf
Device-1: NVIDIA GF116M [GeForce GT 560M] vendor: ASUSTeK driver: nvidia
v: 390.147 alternate: nouveau,nvidia_drm pcie: gen: 2 speed: 5 GT/s
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1251 class-ID: 0300
Device-2: Sunplus Innovation ASUS Webcam type: USB driver: uvcvideo
bus-ID: 1-1.2:4 chip-ID: 1bcf:2885 class-ID: 0e02
loaded: nvidia gpu: nvidia display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 128 s-size: 381x211mm (15.0x8.3")
s-diag: 436mm (17.1")
Monitor-1: LVDS-0 res: 1920x1080 hz: 60 dpi: 128
size: 382x215mm (15.0x8.5") diag: 438mm (17.3")
OpenGL: renderer: GeForce GTX 560M/PCIe/SSE2 v: 4.6.0 NVIDIA 390.147
direct render: Yes
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: NVIDIA GF116 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:0bee class-ID: 0403
Sound Server-1: ALSA v: k5.16.14-zen1-1-zen running: yes
Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter
vendor: AzureWave AW-NB037H 802.11bgn driver: ath9k v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:002b
vendor: ASUSTeK U6V/U31J laptop driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 9000 bus-ID: 05:00.0 chip-ID: 10ec:8168
Device-1: Qualcomm Atheros AR3011 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-1.1:3 chip-ID: 0cf3:3005 class-ID: e001
Local Storage: total: 1.82 TiB used: 12.04 GiB (0.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 2000GB
type: SSD serial: <filter> rev: 04RL scheme: MBR
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 12.04 GiB (0.6%)
fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 12.04 GiB (0.6%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-3: /var/log raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
ID-4: /var/tmp raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
ID-1: swap-1 type: zram size: 11.66 GiB used: 105 MiB (0.9%)
System Temperatures: cpu: 77.0 C mobo: N/A gpu: nvidia temp: 77 C
Fan Speeds (RPM): cpu: 3500
Processes: 305 Uptime: 22h 43m wakeups: 16 Memory: 11.66 GiB
used: 4.78 GiB (41.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1301 lib: 383 Shell: fish
v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.13
e[1;34mGaruda (2.5.6-2):e[0m
e[1;34m System install date:e[0m 2022-03-14
e[1;34m Last full system update:e[0m 2022-03-15 e[1;31m↻
e[1;34m Is partially upgraded: e[0m No
e[1;34m Relevant software: e[0m NetworkManager
e[1;34m Windows dual boot: e[0m <superuser required>
e[1;34m Snapshots: e[0m Snapper
e[1;34m Failed units: e[0m
