can you send the output of
sudo findmnt --verify
and also check if
ls /oldHome
returns an error, if it exists then it should be empty and not return anything.
and also check if
ls /oldHome
/oldHome
is empty
returns:
Success, no errors or warnings detected
Is this with the line added at the end of fstab?
ohh...
[W] your fstab has been modified, but systemd still uses the old version;
use 'systemctl daemon-reload' to reload
0 parse errors, 0 errors, 1 warning
Do this and then the findmnt command again.
Yeah just realized I can not read, now it shows no errors again.
Thatâs strange it canât mount yet wonât give us a proper reason.
In that case, try going with this first option here and remove the line we added at the bottom of fstab. Just keep an live iso usb at hand in case you need to revert using chroot. Itâs not difficult.
Instead of chroot, the emergency mode works as well right?
Btw I havn't even figured out what chroot is till now, just used emergency/recovery mode instead of it.
It said
[FAILED] Failed to mount /home
[DEPEND] Dependency failed for Local File Systems
again
I hope so.
chroot is till now
Chroot does one thingârun a command with a different root directory. The command being run has no idea that anything outside of its jail exists, as it doesnât have any links to it, and as far as itâs aware, is running on the root filesystem anyway. Thereâs nothing above root, so the command canât access anything else.
You use the live USB, the one you used to install garuda and mount the installed garuda partition in this jailed environment and login inside it as root and perform maintenance as root user of this system from a terminal.
Itâs very easy infact when you boot into your live USB you get a welcome screen where one of the options read chroot. Entering chroot is as easy as clicking on it.
Then let's undo the changes and wait for the more experienced members to comment. Sorry, I can't figure out why it's refusing to mount here.
Oh nice to know thx, but for now the emergency mode was enough to revert the changes.
Then letâs undo the changes and wait for the more experienced members to comment.
Sorry, I canât figure out why itâs refusing to mount here.
Thank you a lot for your help and the time you invested anyway
This topic was automatically closed after 14 days. New replies are no longer allowed.
