How to move battery/connection top panel buttons to bottom panel?
I am using Garuda MATE. My main goal is to have more screen space by having one panel, not two mostly empty panels.
I’ve put buttons on the bottom panel already:
screenshot: https://github.com/carcinocron/awesome-list/assets/4094542/1ad65265-e0ee-4780-8030-ccc700966491
However, the battery and wifi panels seem to be not re-creatable.
What should I try?
I am not using mate so take my words with a grain of salt. Shouldn’t things like wifi, notif, battery be bundled in a widget called systray (that’s what it’s called on kde and hyprland) so having the systray on the bottom should work. Or you can download a standalone widget for wifi and put it on bottom.
I don’t have an option called anything like systray, but I did find a work around. I added the workspace switcher and window list panel items to the top panel, deleted the bottom panel, then moved the top panel to the bottom.
