How to install [email protected] on Garuda? Is it possible? Thank you.
https://aur.archlinux.org/packages/foldingathome
Do you mean this
You can install this with
sudo pacman -Syu foldingathome
Optionally for opencl support
sudo pacman -Syu ocl-icd clinfo
As i just added it to repo
Then start its service
systemctl enable foldingathome --now
For nvidia users
systemctl enable foldingathome-nvidia --now
You can install cuda
if your gpu support it
sudo pacman -S cuda
How to start it ?
