How to install davinci resolve in garuda and run without error
Can anyone help me in installing and running davinci resolve 18 without any error i have intel processor and nvidia 3050rtx graphics card
this is the ouput of Garuda-inxi
Kernel: 6.3.4-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=5e2ba1d6-779a-49d5-85c4-ff9812d63912 rw rootflags=subvol=@
quiet rd.luks.uuid=bf59c6dd-e1bb-4958-b081-3c6c835f896e quiet splash
rd.luks.uuid=16783e4c-3c89-42c4-9007-6d14e9484f9c
resume=/dev/mapper/luks-16783e4c-3c89-42c4-9007-6d14e9484f9c loglevel=3
Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 wm: kwin_x11 dm: SDDM
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-dk0xxx
v: Type1ProductConfigId serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 85FA v: 42.47 serial: <filter> UEFI: Insyde v: F.62
date: 11/24/2022
ID-1: BAT1 charge: 38.4 Wh (97.2%) condition: 39.5/52.5 Wh (75.3%)
volts: 12.8 min: 11.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
Device-1: hidpp_battery_1 model: Logitech Wireless Mouse serial: <filter>
charge: 50% (should be ignored) rechargeable: yes status: N/A
Info: model: Intel Core i5-9300H socket: BGA1440 (U3E1) note: check bits: 64
type: MT MCP arch: Coffee Lake gen: core 9 level: v3 note: check built: 2018
process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xA (10)
microcode: 0xF2
L3: 64 MiB desc: 8x8 MiB
Speed (MHz): avg: 2611 high: 4092 min/max: 800/4100 base/boost: 2673/4100
ext-clock: 100 MHz cores: 1: 2400 2: 2400 3: 2400 4: 2400 5: 2400 6: 2400
7: 2400 8: 4092 bogomips: 38400
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Hewlett-Packard
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Hewlett-Packard
driver: N/A alternate: nouveau non-free: 530.xx+
status: current (as of 2023-05) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1c8d class-ID: 0300
Device-3: Chicony HP Wide Vision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:4 chip-ID: 04f2:b627
class-ID: 0e02
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15f5 built: 2019 res: 1920x1080
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.1.1 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct-render: Yes
Device-2: NVIDIA GP107GL High Definition Audio vendor: Hewlett-Packard
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
API: ALSA v: k6.3.4-zen2-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.71 status: n/a (root, process) with:
vendor: Hewlett-Packard driver: r8168 v: 8.051.02-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5
v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 1.14 TiB used: 107.81 GiB (9.2%)
model: MZVLB256HAHQ-000H1 size: 238.47 GiB block-size: physical: 512 B
fw-rev: EXD70H1Q temp: 38.9 C scheme: GPT
SMART: yes health: PASSED on: 292d 14h cycles: 4,933
read-units: 134,095,689 [68.6 TB] written-units: 79,620,986 [40.7 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM049-2GH172
family: Barracuda Pro Compute size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 7200
serial: <filter> fw-rev: RPM2 temp: 40 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 122d 7h cycles: 4682
Old-Age: g-sense error rate: 168 Pre-Fail: attribute: Spin_Retry_Count
ID-1: / raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
used: 107.81 GiB (47.0%) fs: btrfs block-size: 4096 B dev: /dev/dm-0
maj-min: 254:0 mapped: luks-bf59c6dd-e1bb-4958-b081-3c6c835f896e
used: 720 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-4: /var/log raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-5: /var/tmp raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/dm-1 maj-min: 254:1
mapped: luks-16783e4c-3c89-42c4-9007-6d14e9484f9c
ID-2: swap-2 type: zram size: 7.6 GiB used: 1.56 GiB (20.6%) priority: 100
System Temperatures: cpu: 55.0 C pch: 58.0 C mobo: N/A
Processes: 298 Uptime: 8h 0m wakeups: 41321 Memory: available: 7.6 GiB
used: 3.51 GiB (46.2%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1388 libs: 378 tools: octopi,paru,yay Shell: Bash (sudo) v: 5.1.16
running-in: konsole inxi: 3.3.27
System install date:     2023-04-11
Last full system update: 2023-06-01 ↻
It's in the chaotic-aur, so:
$ sudo pacman -S davinci-resolve
