I tried closing Latte and reopening it but the same things seems to happen.
Kernel: 5.18.11-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=dc312809-6c72-4613-8e07-19c04af934e5 rw ro[email protected]
Desktop: KDE Plasma v: 5.25.3 tk: Qt v: 5.15.5 info: latte-dock
Type: Desktop Mobo: ASUSTeK model: PRIME Z390-P v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2417
date: 06/03/2019
Device-1: sony_controller_battery_dc:af:68:f4:7d:7b model: N/A serial: N/A
charge: N/A status: full
Info: model: Intel Core i9-9900K bits: 64 type: MT MCP arch: Coffee Lake
gen: core 9 built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158)
stepping: 0xD (13) microcode: 0xF0
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 872 high: 1965 min/max: 800/5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 1965 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800
14: 800 15: 800 16: 800 bogomips: 115200
Device-1: NVIDIA TU104 [GeForce RTX 2080 SUPER] vendor: ZOTAC
driver: nvidia v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Turing process: TSMC 12nm
built: 2018-22 pcie: gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1e81 class-ID: 0300
Device-2: Razer USA Kiyo Pro type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-2.4.2:8 chip-ID: 1532:0e05 class-ID: 0102
Screen-1: 0 s-res: 1920x1080 s-dpi: 69 s-size: 707x392mm (27.83x15.43")
s-diag: 808mm (31.83")
Monitor-1: DP-0 res: 1920x1080 dpi: 70 size: 698x393mm (27.48x15.47")
diag: 801mm (31.54") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 2080 SUPER/PCIe/SSE2
v: 4.6.0 NVIDIA 515.57 direct render: Yes
v: kernel bus-ID: 1-2.4.2:8 alternate: snd_soc_skl,snd_sof_pci_intel_cnl
chip-ID: 1532:0e05 class-ID: 0102 bus-ID: 00:1f.3 chip-ID: 8086:a348
Device-2: NVIDIA TU104 HD Audio vendor: ZOTAC driver: snd_hda_intel
Device-3: Razer USA Kiyo Pro type: USB driver: snd-usb-audio,uvcvideo
Device-4: C-Media Blue Snowball type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2.4.4:9
chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
Device-5: Sony DualShock 4 [CUH-ZCT2x] type: USB
driver: snd-usb-audio,sony,usbhid bus-ID: 1-3:13 chip-ID: 054c:09cc
Sound Server-1: ALSA v: k5.18.11-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.55 running: yes
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168
driver: btusb v: 0.8 bus-ID: 1-14:3 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 3.67 TiB used: 572.27 GiB (15.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SanDisk model: ADATA SX6000LNP
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: V9002s16
temp: 34.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3000DM008-2DM166
type: HDD rpm: 7200 serial: <filter> rev: CC26 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: PNY model: USB 2.0 FD
size: 14.48 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: PMAP scheme: GPT
ID-1: / raw-size: 2.73 TiB size: 2.73 TiB (100.00%)
used: 572.27 GiB (20.5%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 2.73 TiB size: 2.73 TiB (100.00%)
ID-4: /var/log raw-size: 2.73 TiB size: 2.73 TiB (100.00%)
ID-5: /var/tmp raw-size: 2.73 TiB size: 2.73 TiB (100.00%)
System Temperatures: cpu: 35.0 C mobo: N/A gpu: nvidia temp: 47 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 27%
Processes: 403 Uptime: 2h 39m wakeups: 1 Memory: 31.26 GiB
used: 6.86 GiB (21.9%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 Packages: 1549 pacman: 1543 lib: 487
flatpak: 6 Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.19
Garuda (2.6.5-1):
System install date: 2022-07-13
Last full system update: 2022-07-14 ↻
