How to fix btrfs invalid subvolume
hi there I would like to know how can I fix invalid btrfs sub volume error when updating or installing packages
How did you install.
Did you install on btrfs filesystem ?
If not
You have to remove
sudo pacman -Rnsc timeshift-autosnap grub-btrfs
For upgrade to work
thanks it fixed the issue
Please do not necrobump old threads.
