Hello i cant seem to play "Watch Dogs 2" on garuda linux, it crashes to desktop no matter what i do.
But it works fine for me on pop os.
How can install garuda and pop os side by side and dual boot so i can have the best of both worlds?
Thanks guys
create two partitions, install garuda on one and pop os without a boot loader in the other.
boot garuda and mount the Pop os partition.
to list out the partitions:
lsblk
mount it with:
sudo mount /dev/(partition number) /mnt
and then
sudo grub-mkconfig -o /boot/grub/grub.cfg
and unmount it with
sudo umount /dev/(partition)
or you can use garuda boot options
