Kernel: 6.6.46-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.2.1 clocksource: tsc
avail: acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts
root=UUID=5a0c41fe-8e4c-41ad-b9a3-8bc592e3dd5d rw rootflags=subvol=@ quiet loglevel=3 ibt=off
Console: pty pts/1 DM: SDDM Distro: Garuda base: Arch Linux
Type: Laptop System: LENOVO product: 21E4S2WT00 v: ThinkPad E14 Gen 4
Mobo: LENOVO model: 21E4S2WT00 serial: <superuser required>
part-nu: LENOVO_MT_21E4_BU_Think_FM_ThinkPad E14 Gen 4 uuid: <superuser required> UEFI: LENOVO
v: R1SET55W(1.26) date: 01/23/2024
ID-1: BAT0 charge: 31.4 Wh (55.1%) condition: 57.0/57.0 Wh (100.0%) power: 10.0 W volts: 11.6
min: 11.5 model: LGES LNV-5B11E24665 type: Li-poly serial: <filter> status: discharging
cycles: 4
Info: model: 12th Gen Intel Core i5-1235U bits: 64 type: MST AMCP arch: Alder Lake level: v3
note: check built: 2021+ process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 4
microcode: 0x433
Topology: cpus: 1x cores: 10 mt: 2 tpc: 2 st: 8 threads: 12 smt: enabled cache: L1: 928 KiB
desc: d-8x32 KiB, 2x48 KiB; i-2x32 KiB, 8x64 KiB L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 576 high: 2521 min/max: 400/4400:3300 scaling: driver: intel_pstate
governor: powersave cores: 1: 400 2: 400 3: 2521 4: 400 5: 400 6: 400 7: 400 8: 400 9: 400
10: 400 11: 400 12: 400 bogomips: 59916
Device-1: Intel Alder Lake-UP3 GT2 [Iris Xe Graphics] vendor: Lenovo driver: i915 v: kernel
arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports: active: none off: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:46a8 class-ID: 0300
Device-2: Bison Integrated RGB Camera driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 3-7:3 chip-ID: 5986:2146 class-ID: fe01 serial: <filter>
Display: server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.2 compositor: kwin_wayland driver:
X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915 tty: 120x30
Monitor-1: eDP-1 model: AU Optronics 0x408d built: 2019 res: 1920x1080 dpi: 158 gamma: 1.2
size: 309x174mm (12.17x6.85") diag: 355mm (14") ratio: 16:9 modes: 1920x1080
API: EGL v: 1.5 hw: drv: intel iris platforms: device: 0 drv: iris device: 1 drv: swrast gbm:
drv: iris surfaceless: drv: iris wayland: drv: iris inactive: x11
API: OpenGL v: 4.6 compat-v: 4.5 vendor: mesa v: 24.1.6-arch1.1 note: console (EGL sourced)
renderer: Mesa Intel Graphics (ADL GT2), llvmpipe (LLVM 18.1.8 256 bits)
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu name: Intel Graphics (ADL GT2)
driver: mesa intel v: 24.1.6-arch1.1 device-ID: 8086:46a8 surfaces: wayland device: 1 type: cpu
name: llvmpipe (LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.6-arch1.1 (LLVM 18.1.8)
device-ID: 10005:0000 surfaces: wayland
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:51c8 class-ID: 0401
API: ALSA v: k6.6.46-1-lts status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse status: active
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:51f0 class-ID: 0280
Device-2: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel port: N/A
bus-ID: 00:1f.6 chip-ID: 8086:1a1f class-ID: 0200
Info: services: NetworkManager, sshd, systemd-timesyncd, wpa_supplicant
mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0026 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block:
hardware: no software: no address: <filter> bt-v: 5.2 lmp-v: 11 status: discoverable: no
pairing: no
Local Storage: total: 953.87 GiB used: 34.58 GiB (3.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Transcend model: TS1TMTE400S size: 953.87 GiB
fw-rev: V0804S3 temp: 39.9 C scheme: GPT
ID-1: / raw-size: 953.57 GiB size: 953.57 GiB (100.00%) used: 34.58 GiB (3.6%) fs: btrfs
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 584 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 953.57 GiB size: 953.57 GiB (100.00%) used: 34.58 GiB (3.6%) fs: btrfs
ID-4: /var/log raw-size: 953.57 GiB size: 953.57 GiB (100.00%) used: 34.58 GiB (3.6%)
ID-5: /var/tmp raw-size: 953.57 GiB size: 953.57 GiB (100.00%) used: 34.58 GiB (3.6%)
ID-1: swap-1 type: zram size: 23.16 GiB used: 57.5 MiB (0.2%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 12 dev: /dev/zram0
System Temperatures: cpu: 43.0 C mobo: N/A
Fan Speeds (rpm): fan-1: 0 fan-2: 0
Memory: total: 24 GiB note: est. available: 23.16 GiB used: 4.31 GiB (18.6%)
Processes: 306 Power: uptime: 7h 29m states: freeze,mem,disk suspend: s2idle wakeups: 1
hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 9.25 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd v: 256
Packages: pm: pacman pkgs: 1397 libs: 393 tools: octopi,paru Compilers: gcc: 14.2.1
Shell: garuda-inxi default: fish v: 3.7.1 running-in: pty pts/1 (SSH) inxi: 3.3.35
System install date: 2024-08-17
Last full system update: 2024-08-19 ↻
Relevant software: timeshift NetworkManager dracut
Hello, good day.
My issue is with Starship prompts. I want the Docker symbol to appear when I use commands like docker
and docker-compose
, and the Kubernetes symbol to appear when I use the kubectl
command. However, I haven’t been able to figure out how to do this. Could you please help me?
Thank you.
