How to disable unfocused window transaparency
Hello.
System:    Kernel: 5.15.6-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
           parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=8c3a0aeb-19f1-46a7-9d07-7a8163ab8f01 rw
           [email protected] quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
           systemd.unified_cgroup_hierarchy=1 resume=UUID=5db534b6-bf16-41ae-a0dd-d8f27c954cf2 loglevel=3
           Desktop: sway 1.6.1 vt: 1 dm: N/A Distro: Garuda Linux base: Arch Linux
Machine:   Type: Laptop System: TIMI product: Mi Laptop Pro 15 v: N/A serial: <superuser required> Chassis: type: 10
           Mobo: TIMI model: TM1905 v: AX23XXAXE serial: <superuser required> UEFI: TIMI v: XMACM500P0401 date: 08/18/2020
Battery:   ID-1: BAT0 charge: 28.6 Wh (61.9%) condition: 46.2/60.0 Wh (76.9%) volts: 7.5 min: 7.6 model: SUNWODA R15B01W
           type: Li-ion serial: <filter> status: Discharging
CPU:       Info: Quad Core model: Intel Core i7-10510U bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6
           model-id: 8E (142) stepping: C (12) microcode: EA cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
           flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 36799
           Speed: 2604 MHz min/max: 400/4900 MHz Core speeds (MHz): 1: 2604 2: 2511 3: 3462 4: 3885 5: 3126 6: 3679 7: 3587
           8: 2063
Graphics:  Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Xiaomi driver: i915 v: kernel bus-ID: 00:02.0
           Device-2: NVIDIA GP108M [GeForce MX250] vendor: Xiaomi driver: nouveau v: kernel bus-ID: 01:00.0 chip-ID: 10de:1d13
           class-ID: 0302
           Device-3: Cheng Uei Precision Industry (Foxlink) XiaoMi USB 2.0 Webcam type: USB driver: uvcvideo bus-ID: 1-6:2
           chip-ID: 05c8:03b7 class-ID: 0e02
           Display: wayland server: N/A compositor: sway v: 1.6.1 driver: loaded: nouveau note: n/a (using device driver)
           display-ID: 1 resolution: <missing: xdpyinfo>
Audio:     Device-1: Intel Comet Lake PCH-LP cAVS vendor: Xiaomi driver: snd_hda_intel v: kernel
           alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0403
           Sound Server-1: ALSA v: k5.15.6-zen2-1-zen running: yes
           Sound Server-5: PipeWire v: 0.3.40 running: yes
Network:   Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:02f0
Bluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb v: 0.8 bus-ID: 1-10:5
Drives:    Local Storage: total: 953.87 GiB used: 15.91 GiB (1.7%)
           ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW010T8 size: 953.87 GiB block-size: physical: 512 B
           logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 02CA temp: 30.9 C scheme: GPT
Partition: ID-1: / raw-size: 507.59 GiB size: 507.59 GiB (100.00%) used: 15.91 GiB (3.1%) fs: btrfs dev: /dev/nvme0n1p8
           maj-min: 259:8
           ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p9
           maj-min: 259:9
           ID-3: /home raw-size: 507.59 GiB size: 507.59 GiB (100.00%) used: 15.91 GiB (3.1%) fs: btrfs dev: /dev/nvme0n1p8
           maj-min: 259:8
           ID-4: /var/log raw-size: 507.59 GiB size: 507.59 GiB (100.00%) used: 15.91 GiB (3.1%) fs: btrfs dev: /dev/nvme0n1p8
           maj-min: 259:8
           ID-5: /var/tmp raw-size: 507.59 GiB size: 507.59 GiB (100.00%) used: 15.91 GiB (3.1%) fs: btrfs dev: /dev/nvme0n1p8
           maj-min: 259:8
           ID-1: swap-1 type: partition size: 5.86 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p7 maj-min: 259:7
           ID-2: swap-2 type: zram size: 15.5 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors:   System Temperatures: cpu: 55.0 C pch: 42.0 C mobo: N/A gpu: nouveau temp: 40.0 C
Info:      Processes: 268 Uptime: 19m wakeups: 19 Memory: 15.5 GiB used: 5.82 GiB (37.5%) Init: systemd v: 249 tool: systemctl
           Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1277 lib: 337 Shell: Bash v: 5.1.12 running-in: alacritty
           inxi: 3.3.09
I've just installed Garuda Sway edition and wanna disable window transparency at all. Where I can configure it?
Please search for a solution to your problem before asking.
This is the forth most recent question in the Sway thread: :unamused:
I'm sorry, I've tried to find some similar, but didn't get it
