How to disable default wacom driver to use OpenTabletDriver instead
Okay, I have a wacom tablet (CTH-680) and want to use opentabletdrivers since I play osu! (rhythm game) and need that super low latency and tablet filters. I got the aur installed and the daemon running properly but the problem is there is some system default driver that is running and I can’t find what it is to disable it. I did look at octopi and it says libwacom is installed BUT when I try to remove it it gives me a warning asking if I want to uninstall 628 packages and some of those packages are big ones like SDDM or xorg packages which I obviously need. I need whatever it’s using disabled because I have a 2 monitor setup and it has the area set to both monitors meaning I get this weird glitches 2 cursors teleporting back and forth when I use opentabletdrivers. I know this is a really niche issue but I’d like to know what I should do because this is kind of my main game recently and it’s unplayable because of this.
Kernel: 6.7.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=320a3d94-a878-4536-be5a-56311ec1e186 rw rootflags=subvol=@
Type: Desktop System: HP product: HP Pavilion Gaming Desktop 690-00xx v: N/A
Mobo: HP model: 843B v: 00 serial: <superuser required>
part-nu: 5QA71AA#ABA uuid: <superuser required> UEFI: AMI v: F.48
date: 07/27/2022
Info: model: Intel Core i5-8400 bits: 64 type: MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF4
desc: 1x9 MiB
Speed (MHz): avg: 3801 high: 3805 min/max: 800/4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 3801 2: 3800 3: 3800
4: 3801 5: 3805 6: 3799 bogomips: 33599
Device-1: NVIDIA TU116 [GeForce GTX 1660 Ti] vendor: Hewlett-Packard
status: current (as of 2024-02; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:2182 class-ID: 0300
Device-2: Microdia Webcam Vitade AF driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2
chip-ID: 0c45:6366 class-ID: 0102 serial: <filter>
Screen-1: 0 s-res: 3840x1080 s-dpi: 113 s-size: 863x241mm (33.98x9.49")
s-diag: 896mm (35.28")
Monitor-1: DP-0 pos: primary,left res: 1920x1080 dpi: 93
Monitor-2: HDMI-0 pos: right res: 1920x1080 hz: 60 dpi: 112
size: 435x239mm (17.13x9.41") diag: 496mm (19.54") modes: N/A
Monitor-3: None-1-1 size-res: N/A modes: N/A
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1660 Ti/PCIe/SSE2
memory: 5.86 GiB
API: Vulkan v: 1.3.276 layers: 11 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1660 Ti driver: nvidia v: 545.29.06 device-ID: 10de:2182
surfaces: xcb,xlib
Device-2: NVIDIA TU116 High Definition Audio vendor: Hewlett-Packard
Device-3: Microdia Webcam Vitade AF driver: snd-usb-audio,uvcvideo
Device-4: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:5
chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
API: ALSA v: k6.7.6-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.3 status: active with: 1: pipewire-media-session
status: active 2: pipewire-alsa type: plugin 3: pw-jack type: plugin
tools: pw-cat,pw-cli
Server-2: PulseAudio v: 17.0 status: active with: pulseaudio-jack
type: module tools: pacat,pactl
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A modules: rtw88_8821ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 02:00.0
vendor: Hewlett-Packard RTL8111/8168/8411 driver: r8169 v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
Device-1: Realtek Bluetooth 4.2 Adapter driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:9 chip-ID: 0bda:b00a
Local Storage: total: 5.24 TiB used: 615.66 GiB (11.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520
SDAPNUW-256G-1006 size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
fw-rev: 20110006 temp: 46.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000NM0024-1HT178
tech: HDD rpm: 7200 serial: <filter> fw-rev: SN02 scheme: GPT
model: WD15EADS-00P8B0 size: 1.36 TiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 0A01
scheme: MBR
ID-1: / raw-size: 78.32 GiB size: 78.32 GiB (100.00%)
used: 66.64 GiB (85.1%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 29.4 MiB (30.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 78.32 GiB size: 78.32 GiB (100.00%)
ID-4: /var/log raw-size: 78.32 GiB size: 78.32 GiB (100.00%)
ID-5: /var/tmp raw-size: 78.32 GiB size: 78.32 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.21 GiB used: 3.52 GiB (11.3%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 6
System Temperatures: cpu: 73.0 C pch: 62.0 C mobo: N/A gpu: nvidia
temp: 42 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 47%
Memory: total: 32 GiB available: 31.21 GiB used: 8.79 GiB (28.2%)
Processes: 359 Power: uptime: 5h 3m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.44 GiB services: org_kde_powerdevil,
Packages: 2122 pm: pacman pkgs: 2098 libs: 596 tools: octopi,pamac,paru
pm: appimage pkgs: 0 pm: flatpak pkgs: 24 Compilers: clang: 16.0.6
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.0 running-in: konsole
inxi: 3.3.33
Garuda (2.6.23-1):
System install date:     2024-02-25
Last full system update: 2024-02-26 ↻
What’s the problem with not posting garuda-inxi?
It contains additional, useful information about the status of your system.
:warning: Missing information requested in the template may result in not receiving assistance
Issue still unresolved? Then:
  • ONE issue per topic.
Without garuda-inxi this request will be moved to 412 Precondition Failed
I assumed it was pointless considering this isn’t a crash or like system issue but rather a question just asking how to remove a specific driver safely, my mistake.
Please
Well, I did it before noticing the request.
The inxi was really unreadable, I couldn’t help it…
The documentation here says after you install the AUR package you need to regenerate the initramfs:
sudo dracut-rebuild
Then unload these kernel modules:
sudo rmmod wacom
sudo rmmod hid_uclogic
With garuda-inxi you can see directly whether you are using mkinitcpio or dracut, for example. It saves the helpers a lot of questions until they can help.
Apart from that, not everyone can judge whether it makes sense in their case or not.
We hope that within a few years it will be as natural as brushing your teeth every day to post garuda-inxi when asking for help. :smiley:
Until then, we’ll just post the template again.
Translated with DeepL.com (free version)
I swear I tried using sudo mkinitcpio -P last time but it didn’t work, but after using sudo dracut-rebuild it seems to have actually worked now (although weirdly neither of those modules were loaded when i tried to rmmod them?). Just for learning purpose so I can understand, is there a reason what you gave me worked but not sudo mkinitcpio -P. I’d like to get a better understanding of the difference, if not I can jus do some reserach on my own. Thanks a bunch for the help!
Yeah, I was just being stupid that’s my fault. Thanks for letting me know and sorry for that again.
The reason is this:
For a while now Garuda uses dracut by default (instead of mkinitcpio). If you want to learn more about that, this wiki article is informative but nice and short:
okay okay i see thanks i’ll read some more of this a bit later.
