Any guides on how to decrease lags when using the system? Animations lag for me when i hover on applications bar or do something on top bar
Welcome
Can you provide your
as required
CPU: quad core Intel Core i3-9100F (-MCP-) speed/min/max: 3709/800/4200 MHz
Kernel: 5.16.16-200.fc35.x86_64 x86_64 Up: 2h 58m
Mem: 4218.4/7858.4 MiB (53.7%) Storage: 238.25 GiB (12.2% used) Procs: 324
Shell: Bash inxi: 3.3.13
In terminal ?
use
and post
or use garuda assisant and post the output
pleae help us to help you
okay, be right back
sorry, i were sleeping
actually, i deleted the os before asking. Im trying to install again and im trying to do bootable usb iso again, but balenaetcher fails. Searching for other apps to use to make bootable usb with garuda
Try ventoy to burn your iso
okay, almost done
done,trying garuda-inxi
Kernel: 5.16.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
misobasedir=garuda misolabel=GARUDA_DR460NIZEDGAMING_WHITETAI quiet
systemd.show_status=1 driver=free nouveau.modeset=1 i915.modeset=1
radeon.modeset=1
Desktop: KDE Plasma 5.24.2 tk: Qt 5.15.3 info: latte-dock wm: kwin_x11
Type: Desktop Mobo: ASUSTeK model: PRIME B360M-A v: Rev X.0x
serial: UEFI: American Megatrends v: 3201
date: 04/16/2021
Info: model: Intel Core i3-9100F bits: 64 type: MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xB (11) microcode: 0xD6
Topology: cpus: 1x cores: 4 smt: cache: L1: 256 KiB
desc: 1x6 MiB
Speed (MHz): avg: 4064 high: 4093 min/max: 800/4200 scaling:
driver: intel_pstate governor: performance cores: 1: 4093 2: 4045 3: 4044
4: 4076 bogomips: 28800
IBRS_FW, STIBP: disabled, RSB filling
Device-1: NVIDIA GP108 [GeForce GT 1030] vendor: Micro-Star MSI
driver: nouveau v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 4 link-max:
gen: 3 speed: 8 GT/s ports: active: HDMI-A-1 empty: DVI-D-1
bus-ID: 01:00.0 chip-ID: 10de:1d01 class-ID: 0300
loaded: nouveau unloaded: modesetting alternate: fbdev,nv,vesa gpu: nouveau
s-diag: 582mm (22.9")
Monitor-1: HDMI-1 mapped: HDMI-A-1 model: ViewSonic VA2431 Series
serial: built: 2012 res: 1920x1080 hz: 60 dpi: 94 gamma: 1.2
size: 521x293mm (20.5x11.5") diag: 598mm (23.5") ratio: 16:9 modes:
OpenGL: renderer: NV138 v: 4.3 Mesa 21.3.7 direct render: Yes
Device-2: NVIDIA GP108 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fb8
Sound Server-1: ALSA v: k5.16.12-zen1-1-zen running: yes
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac:
Local Storage: total: 238.5 GiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: AEGO model: SSD 120GB
type: SSD serial: rev: 7A scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Silicon Power
model: SPCC Solid State Disk size: 119.24 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: rev: 9A0
ID-3: /dev/sdc maj-min: 8:32 type: USB model: General USB Flash Disk
size: 7.47 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: rev: 1100 scheme: MBR
ID-1: swap-1 type: zram size: 7.68 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 67.0 C mobo: N/A gpu: nouveau temp: 36.0 C
Processes: 201 Uptime: 1m wakeups: 0 Memory: 7.68 GiB
used: 1.95 GiB (25.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1719 lib: 509 Shell: fish v: 3.3.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.13
Garuda (2.5.5-1):
System install date: 2022-03-27
Last full system update: 2022-03-27
Windows dual boot:
Is there a reson why you are not using nvidia driver as this might be the cause of the slowness
use the garuda assistance to install the proprietary driver
because i dont know how to install nvidia drivers
nvm ill try it
Thank you!
nevermind, still got a problem
Starting
Using config ‘video-nvidia-dkms’ for device: 0000:01:00.0 (0300:10de:1d01) Display controller nVidia Corporation GP108 [GeForce GT 1030]
Installing video-nvidia-dkms…
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/nvidia-dkms/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
:: Synchronizing package databases…
error: failed to synchronize all databases (unable to lock database)
Error: pacman failed!
Error: script failed!
use garuda assistance to remove database lock
then use
garuda-update
and reboot and try again
Thanks! New question: how to disable some animations? How to add buttons on top bar on window like on Windows OS?
