Hey all i was trying to install a voice assistant called mycoft ai from github but running the installation script gave me the error that the package pulseaudio and pipewire-pulse are in conflict, I tried removing pipewire-pulse
but it has some dependencies so I searched how to replace pipewire with pulseaudio but all of the results were the opposite of replacing pulse with pipewire.
I cant use the garuda assistant aswell because it throws a error for a split second which is unreadable while enabling pulse support something like failed to satisfy
Please ask there or open issue on
But i want to remove pipewire and change it to pulse lets forget about the voice assistant how can we swap it because all of the search results showed how to replace pulse with pipe
As always reboot with working snapshot.
ANd search for pipewire pulsaudio in forum
There isnt a error here, I just want to replace pipewire with pulse. I did but I cant remove pipewire-pulse because it has tons of dependent software
sudo pacman -S pulseaudio
I tried it said target not found pulseaudio
Which distro are you running?
Output of pacman -Ss "^pulseaudio$"
It was giving me that error i deleted the local cache and did a sys update and it fixed wierd thing is it never worked before u replied, no cap
That's because my mere presence scares computers into working...
