How to change the output for fish
╭─vorsv@VORSV1 in ~ via  v22 took 1s
[🔍] × garuda-inxi
root=UUID=86f0cadc-032e-4aa4-8c9a-6ce9f9589149 rw rootflags=subvol=@
quiet resume=UUID=6cb7ad08-c086-4bce-b6c4-39f4a9509e88 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.1.1 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Laptop System: HP product: HP EliteBook 830 G5 v: N/A
Mobo: HP model: 83B3 v: KBC Version 04.6E.00 serial: <superuser required>
part-nu: 4YK40UC uuid: <superuser required> UEFI: HP v: Q78 Ver. 01.25.00
date: 06/16/2023
ID-1: BAT0 charge: 14.9 Wh (45.7%) condition: 32.6/50.2 Wh (64.9%)
volts: 12.9 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: charging cycles: 749
Info: model: Intel Core i5-8350U bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF4
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 750 high: 800 min/max: 400/3600 scaling:
5: 400 6: 800 7: 800 8: 800 bogomips: 30399
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:5917 class-ID: 0300
Device-2: Cheng Uei Precision Industry (Foxlink) HP HD Camera
driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-9:4 chip-ID: 05c8:0808 class-ID: 0e02 serial: <filter>
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (KBL
GT2) device-ID: 8086:5917 memory: 15.24 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 9 device: 0 type: integrated-gpu name: Intel
UHD Graphics 620 (KBL GT2) driver: mesa intel v: 24.1.2-arch1.1
device-ID: 8086:5917 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.1.2-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
API: ALSA v: k6.9.7-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.0 status: active with: 1: pipewire-pulse
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:24fd
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3 chip-ID: 8087:0a2b
Local Storage: total: 931.51 GiB used: 24.02 GiB (2.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: SN560E
lanes: 4 tech: SSD serial: <filter> fw-rev: AO009E4O temp: 42.9 C
ID-1: / raw-size: 679.84 GiB size: 679.84 GiB (100.00%)
used: 24.02 GiB (3.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 679.84 GiB size: 679.84 GiB (100.00%)
ID-4: /var/log raw-size: 679.84 GiB size: 679.84 GiB (100.00%)
ID-5: /var/tmp raw-size: 679.84 GiB size: 679.84 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.21 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.33 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 53.0 C pch: 45.5 C mobo: N/A
Memory: total: 32 GiB available: 31.21 GiB used: 5.79 GiB (18.6%)
Processes: 284 Power: uptime: 21m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.47 GiB services: org_kde_powerdevil,
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 2019 libs: 591
tools: octopi,paru Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.35
System install date:     2024-07-01
Last full system update: 2024-07-01
i want to change the output of fish command now this output this
this current version is a reinstall but before this there would be a different logo like a image not like the logo made with texts as in the above image
Hmm, I thought this was already fixed.
Give this a try:
sed -i 's/--config neofetch/--config dr460nized/' ~/.config/fish/config.fish
thanks it worked like a charm
