How to add BF-CBC to openvpn
Hello Garuda users.
  Kernel: 6.4.11-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=6c2e46d1-f010-4685-9e08-05bcb70ab7ed rw rootflags=subvol=@
    apparmor=1 security=apparmor quiet rd.udev.log_priority=3
    vt.global_cursor_default=0 loglevel=3
    resume=UUID=822b0420-2fff-4f14-9b22-9c0b6c166b2e ibt=off
  Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-E GAMING v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 2802
    date: 10/21/2020
  Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
    model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
    L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 4267 min/max: 2200/4650 boost: enabled scaling:
    driver: acpi-cpufreq governor: performance cores: 1: 4267 2: 4267 3: 4267
    4: 4267 5: 4267 6: 4267 7: 4267 8: 4267 9: 4267 10: 4267 11: 4267 12: 4267
    bogomips: 88636
  Device-1: AMD Vega 10 XL/XT [Radeon RX 56/64] vendor: ASUSTeK driver: amdgpu
    v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie:
    gen: 3 speed: 8 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1, DP-2,
    DVI-D-1, HDMI-A-2 bus-ID: 0d:00.0 chip-ID: 1002:687f class-ID: 0300
  Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
    s-diag: 987mm (38.84")
  Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Samsung S34J55x
    serial: <filter> built: 2020 res: 3440x1440 hz: 50 dpi: 110 gamma: 1.2
    size: 797x333mm (31.38x13.11") diag: 864mm (34") modes: max: 3440x1440
    min: 720x400
  API: OpenGL v: 4.6 Mesa 23.1.6 renderer: AMD Radeon RX Vega (vega10 LLVM
    15.0.7 DRM 3.52 6.4.11-zen2-1-zen) direct-render: Yes
  Device-1: AMD Vega 10 HDMI Audio [Radeon 56/64] driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0d:00.1
    chip-ID: 1002:aaf8 class-ID: 0403
    bus-ID: 0f:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.4.11-zen2-1-zen status: kernel-api with: aoss
    speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 06:00.0
  IF: enp6s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-3: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 07:00.0
  IF-ID-1: tun0 state: down mac: N/A
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:4 chip-ID: 8087:0029
  Local Storage: total: 15.92 TiB used: 5.01 TiB (31.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Crucial model: CT500P2SSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P2CR033 temp: 42.9 C
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 1B4QFXO7 temp: 52.9 C
    model: WD50EZRZ-00GZ5B1 size: 4.55 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5700 serial: <filter>
    fw-rev: 0A80 scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Toshiba model: DT01ACA300
    tech: HDD rpm: 7200 serial: <filter> fw-rev: ABB0 scheme: GPT
  ID-5: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST2000DL003-9VT166
    tech: HDD rpm: 5900 serial: <filter> fw-rev: CC32 scheme: MBR
  ID-6: /dev/sdd maj-min: 8:48 vendor: Western Digital
    model: WD60EZAZ-00SF3B0 size: 5.46 TiB block-size: physical: 4096 B
  ID-1: / raw-size: 200 GiB size: 200 GiB (100.00%) used: 28.57 GiB (14.3%)
    used: 576 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p4 maj-min: 259:4
  ID-3: /home raw-size: 631.01 GiB size: 631.01 GiB (100.00%)
    used: 179.67 GiB (28.5%) fs: btrfs dev: /dev/nvme1n1p3 maj-min: 259:3
  ID-4: /var/log raw-size: 200 GiB size: 200 GiB (100.00%)
    used: 28.57 GiB (14.3%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
  ID-5: /var/tmp raw-size: 200 GiB size: 200 GiB (100.00%)
  ID-1: swap-1 type: zram size: 31.25 GiB used: 1005 MiB (3.1%)
  ID-2: swap-2 type: partition size: 100 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme1n1p1 maj-min: 259:1
  System Temperatures: cpu: 68.4 C mobo: 42.0 C gpu: amdgpu temp: 46.0 C
    mem: 45.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 868
  Processes: 439 Uptime: 20m wakeups: 0 Memory: total: 32 GiB
  available: 31.25 GiB used: 13 GiB (41.6%) Init: systemd v: 254
  default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
  Packages: 2390 pm: pacman pkgs: 2379 libs: 593 tools: octopi,paru
  pm: flatpak pkgs: 11 Shell: fish v: 3.6.1 default: Bash v: 5.1.16
  running-in: konsole inxi: 3.3.29
  System install date:     2023-04-06
  Last full system update: 2023-08-23
  Failed units:            clamav-clamonacc.service
I have experienced some problems with my VPN (VyprVPN) conntection. It dropped after 10-20 minutes. I asked support, there is the answer:
"After BF-CBC is selected as the Cipher, please try to reconnect using OpenVPN protocol".
Yes, but BF-CBC was removed from openvpn as Cipher.
So the question is how can I put it back?
Thanks guys!
