Kernel: 6.0.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=7d549f10-2128-425f-a729-a334f876d69d rw [email protected]
Desktop: i3 v: 4.21.1 info: i3bar vt: 7 dm: LightDM v: 1.32.0
Type: Desktop System: Gigabyte product: N/A v: N/A
Mobo: Gigabyte model: H110M-DS2-CF v: x.x serial: <superuser required>
UEFI: American Megatrends v: F2 date: 10/30/2015
Info: model: Intel Core i5-6500 bits: 64 type: MCP arch: Skylake-S
desc: 1x6 MiB
Speed (MHz): avg: 3404 high: 3425 min/max: 800/3600 scaling:
driver: intel_pstate governor: performance cores: 1: 3395 2: 3425 3: 3400
4: 3396 bogomips: 25599
disabled
Type: mmio_stale_data mitigation: Clear CPU buffers; SMT disabled
PBRSB-eIBRS: Not affected
Device-1: AMD Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X]
vendor: Sapphire driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
process: GF 14nm built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 1
link-max: lanes: 8 ports: active: HDMI-A-1 empty: DP-1,DVI-D-1
bus-ID: 01:00.0 chip-ID: 1002:699f class-ID: 0300 temp: 46.0 C
Display: x11 server: X.Org v: 21.1.4 compositor: Picom v: git-98a5c
driver: X: loaded: modesetting dri: radeonsi gpu: amdgpu display-ID: :0
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Samsung S24F350 serial: <filter>
built: 2017 res: 1920x1080 hz: 60 dpi: 94 gamma: 1.2
size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9 modes:
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: AMD Radeon RX 550 / 550 Series
(polaris12 LLVM 14.0.6 DRM 3.48 6.0.9-zen1-1-zen) direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Gigabyte
driver: snd_hda_intel bus-ID: 1-4:4 v: kernel bus-ID: 00:1f.3
chip-ID: 1e7d:3a3b class-ID: 0300 chip-ID: 8086:a170 serial: <filter>
Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
vendor: Sapphire driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 1 link-max: lanes: 8 bus-ID: 01:00.1 chip-ID: 1002:aae0
Device-3: ROCCAT SYN Pro Air type: USB
Sound API: ALSA v: k6.0.9-zen1-1-zen running: yes
Sound Server-2: PipeWire v: 0.3.60 running: yes
Local Storage: total: 1.38 TiB used: 56.51 GiB (4.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 model: PS3109S9 size: 20 MiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: N/A serial: N/A
rev: OOT2
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 QVO 1TB
type: SSD serial: <filter> rev: 1B6Q
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: SanDisk model: Cruzer Blade
size: 14.32 GiB block-size: physical: 512 B logical: 512 B type: N/A
used: 56.51 GiB (12.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 15.58 GiB used: 3.8 MiB (0.0%) priority: 100
System Temperatures: cpu: 64.0 C pch: 39.5 C mobo: N/A gpu: amdgpu
temp: 46.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1030
Processes: 242 Uptime: 22m wakeups: 0 Memory: 15.58 GiB
used: 2.86 GiB (18.3%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1446
libs: 456 tools: pamac,paru Shell: Bash v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-11-25
Last full system update: 2022-11-26
so funny thing... I don't know if I'm running of iGPU or my actual dedicated graphics card.
when I do
glxgears -info
Running synchronized to the vertical refresh. The framerate should be
approximately the same as the monitor refresh rate.
GL_RENDERER = AMD Radeon RX 550 / 550 Series (polaris12, LLVM 14.0.6, DRM 3.48, 6.0.9-zen1-1-zen)
GL_VERSION = 4.6 (Compatibility Profile) Mesa 22.2.3
GL_VENDOR = AMD
is shows as if I am runing from the AMD drivers... which is great!
but when I check with optimus...
optimus-manager --print-mode
Current GPU mode : integrated
I am suspecting optimus doens't know how to read AMD?
the thing is, I am trying to play starsector a pretty lightweight game (2d graphics...) but there is this particular effect that is causing trouble.
I asked in the forums but all rivers lead to the same problem... either drivers or hardware. but someone pointed out that even on integrated the game can run fine... and the effect might only be too intense if I dont use the dedicated.
help
edit: I found a solution to my problem, the problem was that the drivers ware open source and the game I am runing doesn't play well with them with that particular effect.
I follow the archwiki to install the proprietery drivers (There is a PKG for building a fixed version of the drivers to bypass the careless release of AMD that is broken, because of libc6 mismatch of versions or something)
while the pro drivers are dogshit(sorry...) they are enough to run the game optimally (60+ fps), it is a SUPER lightweight game tho.
