How do I make the shell look inside a folder recusively using `$PATH`?
garuda-inxi Garuda's PrivateBin
How can I add a folder in $PATH, that also tells the shell to look inside recursively?
For example, I have some portable apps installed in folder X. I want to be able to execute them by just typing their name. I know this can be accomplished by adding the folder to $PATH.
The problem is adding new folders to $PATH is very annoying, even when it's saved via smth like .zshrc.
Is there a way to use something like
/home/archbtw/Folder X/* (as in look inside recursively)
in $PATH?
Something like this might work:
yep it does! Thanks.
