Hi, i've been using Garuda for a couple months and its awesome, i had some problems with one update but i resolved it already.
Now I have another problem, every time I open "Konsole" it shows a lot of warning messages about starship, I tried uninstalling it, replace it with starship-git, but the warning messages still showing.
[WARN] - (starship::configs::starship_root): Unknown config key 'docker'
[WARN] - (starship::configs::starship_root): Did you mean 'docker_context'?
[WARN] - (starship::configs::starship_root): Unknown config key 'haskell'
[WARN] - (starship::configs::starship_root): Did you mean 'shell'?
[WARN] - (starship::configs::character): Unknown config key 'use_symbol_for_status'
What do i do?
