So basically, whenever I restart my garuda linux (running KDE Plasma 6 on it), the below app panel glitches. I have to either: enter edit mode, take screenshot or launch some app from application launcher to revert it back to normal. It’s extremely annoying and I have found no solution regarding it. I do not know if it’s a KDE only issue or related to garuda Dr460nized theme, hence I am posting it here. I am a beginner so I apologise if this is a dumb question or shouldn’t be posted here.
Here is the image of my desktop:
After booting: Pasteboard - Uploaded Image
After opening some app or entering edit mode: Pasteboard - Uploaded Image
This issue was faced ever since I installed garuda linux, around maybe a month ago. I had also re-installed garuda for some other reasons but this issue did not seem to stop.
Any help will be appreciated!
P.S. When I am trying to enter edit mode now, “Enter Edit Mode” option no longer works and doesn’t do anything. Also one other thing, whenever I tried to add widgets to my desktop or panel via edit mode, KDE just crashes then restarts itself and it doesn’t work. Is this normal for garuda? I know one issue per post, but I am just asking it, not trying to fix it as I am kinda fine without using widgets, though I’d love to use 'em if I had the option.
Thank you so much in advanced!
garuda-inxi output:
Kernel: 6.12.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=6d7c48e7-3eb2-4f31-aade-996b49a62496 rw rootflags=subvol=@
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X512DA_X512DA
Mobo: ASUSTeK model: X512DA v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: X512DA.318
date: 09/28/2022
ID-1: BAT0 charge: 21.7 Wh (77.0%) condition: 28.2/37.1 Wh (75.9%)
power: 6.9 W volts: 7.8 min: 7.8 model: ASUSTeK ASUS Battery type: Li-ion
serial: N/A status: discharging cycles: 623
Info: model: AMD Ryzen 3 3200U with Radeon Vega Mobile Gfx bits: 64
Topology: cpus: 1x dies: 1 clusters: 1 cores: 2 threads: 4 tpc: 2
smt: enabled cache: L1: 192 KiB desc: d-2x32 KiB; i-2x64 KiB L2: 1024 KiB
desc: 2x512 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1400 min/max: 1400/2600 boost: disabled scaling:
driver: acpi-cpufreq governor: powersave cores: 1: 1400 2: 1400 3: 1400
4: 1400 bogomips: 20761
Device-1: Advanced Micro Devices [AMD/ATI] Picasso/Raven 2 [Radeon Vega
Series / Radeon Mobile Series] vendor: ASUSTeK driver: amdgpu v: kernel
speed: 8 GT/s lanes: 16 ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 03:00.0 chip-ID: 1002:15d8 class-ID: 0300 temp: 44.0 C
Device-2: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6.2:6
chip-ID: 13d3:56dd class-ID: 0e02 serial: <filter>
Monitor-1: eDP-1 model: AU Optronics 0x21ed built: 2021 res:
mode: 1920x1080 hz: 60 scale: 125% (1.25) to: 1536x864 dpi: 142 gamma: 1.2
size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 3 Graphics
(radeonsi raven2 LLVM 19.1.7 DRM 3.59 6.12.10-zen1-1-zen)
device-ID: 1002:15d8 memory: 1.95 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.303 layers: 14 device: 0 type: integrated-gpu name: AMD
Radeon Vega 3 Graphics (RADV RAVEN2) driver: N/A device-ID: 1002:15d8
Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
Audio driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x, snd_pci_acp5x,
lanes: 16 bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.12.10-zen1-1-zen status: kernel-api with: aoss
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:24fd class-ID: 0280
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6.1:5
chip-ID: 8087:0a2b class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.2
Local Storage: total: 238.47 GiB used: 45.08 GiB (18.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-256G-1002 size: 238.47 GiB block-size: physical: 512 B
fw-rev: 21106000 temp: 41.9 C scheme: GPT
ID-1: / raw-size: 205.64 GiB size: 205.64 GiB (100.00%)
used: 45.06 GiB (21.9%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-2: /boot/efi raw-size: 600 MiB size: 598.8 MiB (99.80%)
used: 19 MiB (3.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 205.64 GiB size: 205.64 GiB (100.00%)
ID-4: /var/log raw-size: 205.64 GiB size: 205.64 GiB (100.00%)
ID-5: /var/tmp raw-size: 205.64 GiB size: 205.64 GiB (100.00%)
ID-1: swap-1 type: zram size: 5.74 GiB used: 282.2 MiB (4.8%)
max-streams: 4 dev: /dev/zram0
System Temperatures: cpu: 44.1 C mobo: N/A gpu: amdgpu temp: 44.0 C
Fan Speeds (rpm): cpu: 2400
Memory: total: 6 GiB available: 5.74 GiB used: 3.83 GiB (66.8%)
Processes: 278 Power: uptime: 2m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 2.28 GiB services: org_kde_powerdevil,upowerd
Packages: pm: pacman pkgs: 2321 libs: 562 tools: octopi,paru,yay
pm: flatpak pkgs: 0 Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: kitty inxi: 3.3.37
Garuda (2.6.26-1.1):
System install date: 2025-01-15
Last full system update: 2025-01-27
Relevant software: snapper NetworkManager dracut grub-customizer
